So I was loading 10' 2x10's into my Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by nerfer, Aug 3, 2007.
  1. nerfer
    nerfer A young senior member
    2,507
    235
    28
    Chicagoland, IL, USA, Earth
    I was feeling kind of smug for being able to use my 50+ mpg vehicle to haul heavy timbers, and wasn't watching the board I was swinging around. Hit my rear taillight, just a 1/2" from the end. So it's cracked, but no pieces fell out. Is this something I can fix with some epoxy or something? (I put some clear packaging tape over it for now, have to be close to see it).
    If not, is there an aftermarket/junkyard supplier of this? I tried doing some google searches, but didn't get reputable hits. I thought perhaps among the good people of this board some may have some experience in this matter. I only need the tail light housing, no bulbs or anything.
    The good news is, I was able to transport the ten-foot 2x10's (pressure treated, so they're heavy) home without any problems. I did have to put a bungee cord thru the latch to the tie-downs, as the Prius can only load 8-foot lengths with the hatch down.
  2. koa
    koa Active Member
    980
    45
    Hawaii
    I don't think epoxy will work without creating a mess. You might try a shop that sells Plexiglas and get some glue from them. Usually to glue Plexiglas you tape parts together dry and use a syringe type applicator to let the glue weep into seam. Some crazy glues might also work. I wonder if the 3M clear paint protector film would work.
  3. GadgetMan2
    GadgetMan2 New Member
    55
    <div class='quotetop'>QUOTE(nerfer @ Aug 3 2007, 02:27 AM) [snapback]489825[/snapback]</div>
    http://cgi.ebay.com/ebaymotors/2007-Toyota...sspagenameZWDVW
  4. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    That one on Ebay looks like the way to go, esp. if you can get it for that price.
  6. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    I saw a bunch of taillight assemblies on the shelves at AutoBeYours.
    _H*
  7. eastender43
    eastender43 Junior Member
    Get some thin superglue,not the gel,and carefully bleed it into the cracks... If it does run,Do NOT try to wipe it off,just be real careful bleeding it in...When it cures it should be invisible,and check to be sure the cracks have sealed...visually...not with a hose...
    These new tailights crack very easily...you might crack a new one if you replace it....
    And besides,I think RE-USE should be part of owning a green car...The taillight will look good if you are careful,and will function as good as the one that went for $174 on Ebay yesterday..
    <div class='quotetop'>QUOTE(nerfer @ Aug 3 2007, 01:27 AM) [snapback]489825[/snapback]</div>
