So much for veepeak
Discussion in 'Gen 2 Prius Main Forum' started by Stu9, Mar 28, 2025.
  1. Stu9
    Stu9 Junior Member
    84
    Near Mearns
    And Dr Prius...I got it today hoping to mainly to turn off the dam reverse beep only find that it isn't available in the gen 2.
    Waste of money in my case plus some of the stuff to test ie full battery test I need to pay for.
    I will probably sell it to someone as I doubt I will use it again. Not happy.
    Not the car won't start, no ignition lights, nothing.
    When with the fob out the eml is on all the time.... what has happened.
    #1 Stu9, Mar 28, 2025
    51,011
    what does the voltage measure at the jump point under the hood with the car off?
  3. Mendel Leisk
    40,457
    What’s “eml”?
  4. Stu9
    Stu9 Junior Member
    84
    Near Mearns
    Didn't check it.
  5. Stu9
    Stu9 Junior Member
    84
    Near Mearns
    Engine management light.
    As I say though, I am not impressed with the thing at all. I only got it to turn off these dam beeps and it won't work on the gen 2. Waste of money to me.
  6. ColoradoCrow
    ColoradoCrow Senior Member
    1,090
    448
    Leawood, KS
    I
    Try this... If not disassemble the dash and cut the wire to the speaker in the Combination meter. Or muffle it with a piece of foam and gorilla tape, Or fill the speaker with hot glue to prevent it from vibrating..
  7. mr_guy_mann
    mr_guy_mann Senior Member
    3,939
    1,900
    NJ-USA
  8. Goodcitizen
    Goodcitizen Member
    74
    30
    Cali
    Regarding the reverse beep i turned it off using the chicken dance style YouTube videos on both gen2s I've owned.
    Your no start, no power issue could use a better explanation. Have you checked 12v voltage? Does the brake booster activate like normal when walking near or around the vehicle? What about when pressing the brake. Do your interior lights turn on, how about headlights?
  9. Paul Gregory
    Paul Gregory Senior Member
    1,363
    356
    Alberta
    2024 Prius Prime
    XSE
    I had a cheap ELM BT OBD plug I got online somewhere, probably Aliexpress. It kept draining my battery, so I quit using it.
    Now I have a Vgate iCar Pro Bluetooth 4.0 OBD2, which has a power-save feature when it's not being accessed. It stays plugged in all the time, although the LED indicator lights stay on. So far it hasn't caused any problems.
  10. Paul Gregory
    1,363
    356
    Alberta
    2024 Prius Prime
    XSE
    Just curious, would you still want to turn off the reverse beeper if it injured someone who didn't hear you coming?
  11. BiomedO1
    BiomedO1 Senior Member
    2,725
    1,455
    SacTown, Ca
    I'm pretty sure the reverse beeper only sounds inside the passenger compartment of the car - it's NOT an external horn like commercial trucks.
    FWIW: I used the correct Veepeak in my gen4 to get the reverse to a single beep with no issues. You have alternative ways to silence that reverse beeper in gen2 & gen3.
  12. pasadena_commut
    pasadena_commut Senior Member
    2,215
    661
    Southern California
    Never had a problem with my Veepeak dongle either. It worked fine with Dr. Prius and Torque.
  13. Paul Gregory
    1,363
    356
    Alberta
    2024 Prius Prime
    XSE
    Can't get mine to work with Torque. It was one of the apps recommended by VGate.
  14. Mendel Leisk
    40,457
    And it's purpose is to warn the driver he/she's in reverse. It's a bandage solution for the return-to-centre shifter. Oh, there's also typically a column display of the "gears" on the dash, and the current gear has a lit-up surround. Neither measure is that effective, compared to the traditional automatic shifter.
  15. pasadena_commut
    2,215
    661
    Southern California
    Torque is no longer supported and needs older versions of Android. If your phone has anything recent Torque may not work at all, regardless of which dongle it talks to.
  16. Stu9
    Stu9 Junior Member
    84
    Near Mearns
    I tried that too but no, will try again though incase I missed something.
    I am not starting to take things like that to bits just to stop a beep.
    On the veepeak/Dr Prius it gives the two boxes at the top left to tick but when you do it says 'not available on the gen 2".
    Now I was sure the videos I watched were in gen 2s, all American yes for some reason but American. British is obviously different.
  17. dolj
    dolj Senior Member
    8,182
    4,167
    Wellington, New Zealand
    Yes, those procedures only work on the North American model.
    There was one comment recently in another thread from a Brit were he stated he was able to turn off some beeps using an app, but don't quote me on that.
