So my 2 month old car went completely dead…
Discussion in 'Gen 5 Prius Main Forum' started by prius_amy, Nov 27, 2023.
  1. prius_amy
    prius_amy Member
    32
    28
    Portland, Oregon
    I have a ‘23 XSE Prime with barely 2000 miles on it. Just took it on a roadtrip this past Friday (about 300 miles round trip). Got home safely without incident, parked it in the driveway and plugged it in to charge. Woke up the next morning to go to work and found it completely dead. Fob wasn’t responding, car didn’t turn on, couldn’t even get the charging cord disconnected because I couldn’t unlock it. I ended up having the car towed to my local dealer with ToyotaCare roadside assistance. Unfortunately they couldn’t fix the issue that day and closed for the weekend so my car is still there today. Just got this text message from them so who knows what will happen. Will keep you all posted. Also wondering, anyone else have something like this happen?
    otatrant, Gokhan and bisco like this.
  2. hill
    8,793
    The only thing more disappointing than a brand new car that has to go to the shop - is brand new car in the shop & they can't easily figure out what it is. Welcome to many people's experience with new tech including yours truly. Here's to hoping they figured out sooner than later.
  3. prius_amy
    prius_amy Member
    32
    28
    Portland, Oregon
    Yep, exactly. I was really hoping it was just a bad 12V battery but seems the mystery only deepens. Sorry to hear you are also having issues.
  4. BiomedO1
    BiomedO1 Senior Member
    3,488
    1,811
    SacTown, Ca
    Someone posted a similar issue with their new Prius a few months back. Did you or the dealership install any aftermarket electronics? A lot of dealerships install aftermarket trackers into their cars to prevent thief. Perhaps that's what's drawing down the battery. That's just a guess. According to the text, all they did was recharge the 12 VDC battery, under the hood.
    I hope they figure it out
    Louis19 likes this.
  5. bisco
    51,840
    I hope it’s just a defective 12 volt, and they’re too stupid to know it
    prius_amy likes this.
  6. prius_amy
    prius_amy Member
    32
    28
    Portland, Oregon
    Thanks, me too. I did not install any electronics but I will ask them about the tracker thing and see if it’s something they are overlooking. Would be awesome if it was something simple like that.
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Looks pretty obvious to me. The monster sized cat was probably turning the lights on and off trying to get someone's attention to let him out. No litter in there....
    Wiyosaya, FuelMiser and douglasjre like this.
  8. Mr.Vanvandenburg
    1,352
    570
    2020 Prius Prime
    Not as bad as your incident, but it’s good to carry a small jump starter. I am surprised the tow service didn’t jump start it. There is a mechanical key. I assume the hood latch hasn’t gone electronic?
  9. bisco
    51,840
    battery is in the hatch, but the same reasoning applies
  10. Doug McC
    Doug McC Senior Member
    1,079
    416
    Midwest
    2022 Prius
    My fears are we are beginning to see the Toyota becoming the next version of the late 1970’s Chrysler Corporation.
  11. Gokhan
    Gokhan Senior Member
    6,147
    2,431
    Paramount CA
    Lovely cat!
    If the battery deep-discharged even only once, I would ask it to be replaced. Flooded lead–acid batteries don't take deep discharges well.
    You didn't accidentally leave the car in the ACC mode or with the lights on overnight, right? If no such thing happened, then the battery did not charge during the road trip, which would be very strange.
    Doug McC likes this.
  12. fuzzy1
    10,406
    That would be for her original 2013, not this 2023.
  13. Gokhan
    6,147
    2,431
    Paramount CA
    The Gen 5 12-V battery is in the right corner of the trunk with a drain hose attached.
  14. bisco
    51,840
    it's back in the hatch
  15. Gokhan
    6,147
    2,431
    Paramount CA
    I am guessing that the OP—coming from a long road trip and being very tired as a result—might have accidentally left the car in the ACC mode overnight. This would drain the battery. Pressing the on/off button twice instead of once would do that. I always double-check to see if the car is off before I leave. Since Priuses are silent cars, it is very easy to accidentally leave them in the ACC mode or even in the READY mode. This could also be very dangerous with the exhaust fumes filling the garage and house when the engine eventually kicks in after the HEV/PHEV battery is depleted if left in the READY mode.
    #15 Gokhan, Nov 27, 2023
  16. douglasjre
    douglasjre Senior Member
    2,162
    714
    Null, NL
    Will u provide result when discovered
  17. fuzzy1
    10,406
    They moved it again?
  18. CruisnGrrl
    CruisnGrrl Active Member
    149
    128
    Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Surprised they towed it like that, I was told by the dealer that the car had to be on a flatbed because of the regenerative braking. It's quite possible that the tow company further damaged your car.
    daisy555 likes this.
  19. KMO
    KMO Senior Member
    1,947
    676
    Finland
    2023 Prius Prime
    The electric system is only on the front wheels. It's only those you mustn't be spinning while towing.
    If it was an AWD model, then towing like that would not be appropriate - electrics on the rear wheels too.
    Section 7.2 of the US non-Prime manual makes the FWD/AWD distinction. Section 8.2 of the US Prime manual just covers the FWD case - don't spin the front wheels.
    I can imagine your dealer having a simple "always flatbed for hybrids" rule just to keep it simple and prevent error.
    #19 KMO, Nov 28, 2023
    mountaineer likes this.
  20. Gwyd
    Gwyd Member
    113
    78
    NE Florida
    2023 Prius
    Jeez, you are always so quick to blame the user for everything. These are mechanical things and *can* break without user error. It's no secret the Primes have had 12v battery issues - why wouldn't you assume that well known issue is the problem instead of jumping all over the user? You really think everyone is stupid - except you and your car of course.
    I'd bet there were several trips to the car and back to get luggage and other belongings, during which time they would have noticed the car running or the dash lights were on.
    Besides - and correct me if I'm wrong - but does the Prime even turn on when it's plugged in? If it does, I assume it would only be in EV mode which means it doesn't need the 12v for anything, therefore it couldn't have drained it.
    douglasjre and Trollbait like this.
