So my Prius is smarter than me.....
Discussion in 'Newbie Forum' started by The Electric Me, Jun 5, 2013.
  1. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I'm posting this in the Newbie forum because I think I just made my first real newbie Prius mistake.
    The other night, I go out to my Prius, I get in press the brake, release the emergency brake, and hit the power button. The vehicle powers up. I put it in reverse...OMG! The flashing warning triangle! The message on the screen tells me to put the vehicle in park! I do. I try powering up again....put the vehicle in reverse...same outcome....
    So now I'm thinking "Damn..Brand New Prius and there is something wrong". I'm instantly thinking of Tow Trucks, service departements, warranty coverage...all the aspects of New Car "problem" that an owner wants to avoid.
    I turn the vehicle off and take a deep breath and look a little harder.
    Guess who didn't quite get his drivers side door closed? Me.
    The Prius was just warning me that my door wasn't closed. I close the door, power up...all is well. My Prius is smarter than me.
    Semi related Newbie note....
    Since getting The Prius I have filled up only 3 times, all less than 10 gallons. The first two times I filled up when the final Pip started to blink. But I noticed that it took less than 10 gallons. This last tank? The final Pip started to blink but I drove past that point until I had reached Distance to Empty as being 0.
    I was a little nervous about this, but I did it in an area where I felt safe and was close to many gas stations. I actually drove beyond the point it said distance to empty was zero. When I filled according to the pump at the gas station it still took less than 10 gallons.
    I'll probably never purposely do this again. But I just wanted to see what the capability was, and it seems I can easily drive the DTE.
    Since I have read all the cautionary tales. And with the great range of The Prius, I see little advantage in pushing it, I probably will continue to fill up at either 2 pips...or the one pip. But I was surprised that I could go over 30 more miles once the last pip started blinking, all the way to DTE Zero, and still according to the pump I put in less than 10 gallons of gas.
    Which is kind of amazing, since I had driven a total range of about 460 miles on that tank, and if the gas station pump is accurate, it would of seemed to suggest I could of easily broken a 500 mile tank if I had the "balls" to keep pushing it beyond the DTE.
    But one Newbie mistake a month is good enough for me.
    mmmodem likes this.
  2. Noel van
    Noel van Junior Member
    31
    Thanks for sharing.... Good to know that you can drive +/-30 miles once the last pip starts blinking..... I don't have to stress out anymore.
  3. The Electric Me
    9,083
    5,798
    Ahh...please don't necessarily go with my personal experience. I've read that you could, some people can and do, I did this time...BUT I was sweating bullets if only because the feedback from the screen is that your final PIP is blinking AND you are at DTE ZERO...which at least psychologically is telling you " Fill Up Stupid" you're empty.
    I just wouldn't want to hear about somebody running out of gas because they read from my post you COULD go to DTE easily.
    Experiment as always at your own risk. ----I did do it on a stretch of highway with easy shoulders to reach, and also multiple gas stations in many directions.
    As I said, this isn't a game I intend to play. I don't really see much advantage other than full tank distance bragging rights. From now on? I'll probably just fill up with 2 or 1 pip remaining...I'll just know I don't have to worry about it at that point at all.
    49,378
    now you know what range anxiety is for ev'ers. yes, the prius is smart, but if it was really smart, it would say, 'please close the driver door before departing'.:p
  5. Deets
    Deets Junior Member
    Ocala Fl.
    I drive over 2000 miles a month and never fill up untill I reach 530 miles on the trip meter. The last light starts blinking about 470 miles and I ignor it. The car never takes more than 10.5 gallons. So in my head I still have a gallon left in the tank. I'm loving my Prius and I'm looking forward to seeing how many miles it will hang in there . It replaced my 2008 Trailblazer with 280,000 miles that only got 16mpg.
  6. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    OHMYGOSH. Thank you for this post. I've received that error message 3 times since I got the car as you described. I thought what terrible luck to have an electrical problem in my brand new car. Probably won't be able to reproduce it at all to the dealer since I thought it was random.
    To return the favor or as a another nugget of "newbieness", on two occasions I've turned on the car and the instrument panel is black. This is at night. The other interior lights are illuminated but the HSI and speedometer are blank. And because the ICE isn't on I can't tell what is going on. Turns out, the dimmer switch is turned off. I thought my car had an electrical problem again.
    I've driven my PiP a max of 25 miles beyond DTE=0. I filled up 8.7 gallons.
    Deets likes this.
  7. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    The sad part is there is nothing preventing a simple message of "Door Ajar". It would only make sense to provide additional info to go with a triangle symbol whose only function is to scare the driver.
    The 2001-3 Prius had a novel picture of a Turtle as one of the warning symbols. Just think of how many ways that can be misinterpreted.
