So WHY does the regen have to cut out?
Discussion in 'Gen 3 Prius Technical Discussion' started by efusco, Feb 6, 2010.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    With the Tesla Roadster regenerative braking continues from when the accelerator is released until the car stops, even when the friction brakes are engaged. Tesla owners/drivers describe that system as seamless, smooth and effective.
    With the 2G and 3G Prius you can brake with regenerative braking down to 7mph where the regen cuts out completely in favor of friction or if there is a trigger from the skid control ECU such as the now well known 'bump/brake cut out issue'.
    My question for Patrick or others 'in the know'...why is the Prius designed to completely stop regeneration...why not continue until the care is completely stopped and use it to augment the friction brakes even in an emergency/sudden/hard braking situation?:confused:
    If regenerative braking never stopped this whole 'transition' issue would never have occured or had to be addressed.
  2. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Evan,
    I cant speak to the purely electrical/HSD reasons for the regen cut out.
    However, I have read that the 8 MPH cut out/crossover helps keep the
    little used brake disks/drums swept clean of rust for maximum
    effectiveness/smoothness should it be needed at some point.
    I suppose the same thing could be achieved with combined
    regen/mechanical stopping below 8 MPH. :confused:
  3. efusco
    19,891
    1,192
    Nixa, MO
    I'm confused too...and frankly stunned that this thread didn't attract more interest, I think it's a darn good question.
  4. sciguy125
    sciguy125 Junior Member
    CA
    As am I. I'm thinking that since it isn't being covered by the media, nobody cares.
    As for your original question, my guess is that Toyota hasn't figured out how to get a seemless transition. This sort of thing can't possibly be easy. Also, Telsa has the advantage of not having to deal with an engine. MG1 and MG2 have to work together to be able to run an engine while trying to slow down.
  5. efusco
    19,891
    1,192
    Nixa, MO
    That's the beauty though, there's no need for ANY transition. You've already disengaged the ICE from MG2 while regen braking, just keep MG2 engaged and simultaneously engage the friction brakes just like the Tesla. I'm sure there's something else involved or they would have done it that way, but I've not heard anyone explain it.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Perhaps it would be patent infringement? I think it is a good question too and I just don't think anyone really has a good reason. Although it has been mentioned that MG1/2 needs to be protected from a huge inrush.
  7. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I remember something along the lines that below 7mph there is not enough current for regen to be useful/effective. If I'm not mistaken I believe it was Hobbit that explained it and explained it in one of his technical session at Hybridfest.
  8. Tideland Prius
    16,125
    That is a very good question Evan. On the flipside, couldn't they activate the friction brakes earlier while regeneration is still occuring? I know, it'll help reduce brake pad wear by using the current setup but if at those speeds, it can't be wearing out the pads that much, can it? Applying more force with the friction brakes might help. Again, I haven't noticed it in the Gen III. The first thing I remembered was "wow, I can't feel the switchover point, now I have to find some other method of figure out how much brake pressure to apply so I know whether I'm on regen or friction braking"
  9. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    As you slow the MG rotation rate drops. As that drops the output also drops. Critically, the voltage drops along with the current. When the voltage gets too low, you don't have enough to generate the output needed to actually -charge- the battery. Also, as the input voltage drops the inverter current can get pretty high if it is trying to maintain the output. So it will also dramatically effect the design of the inverter. Remember, the MGs run on 540 or so volts, while the battery is a 200 or so Volt device, so you have to design the inverter/charger to operate over a wide range of voltages in the MG side but a narrow range on the output side. I suspect the input range would be exceeded at low speeds/RPMs.
    It is probably also true that when the output voltage of the MGs gets too low, you would experience some rather weird and possibly abrupt load changes on the system. Engineers try to control when those happen, hence the cutoff when -they- decree it should be.
    The Tesla doesn't have an ICE to make the system more complex. For them, I suspect at low speeds they actually don't regenerate. They just don't specify a cutoff speed.
  10. efusco
    19,891
    1,192
    Nixa, MO
    Thanks David, that certainly seems a plausible explanation for the low-speed cut off.
    However, it leaves open the question for the need to cut off the regen at higher speeds when you hit a bump. It also would seem logical to activate friction BEFORE cutting out regen in both low speed and emergency braking situations.
  11. bwilson4web
    15,511
    The first thing to understand is the voltage and power generated by MG2 is driven by the rpm. There is an excellent "REPORT ON TOYOTA/PRIUS MOTOR TORQUE CAPABILITY, TORQUE PROPERTY, NO-LOAD BACK EMF, AND MECHANICAL LOSSES", Hsu, J.S., Ayers, C.W., Commer, C.L., Wiles, R.H., Campbell, S.L., Lowe, K.T., and Michelhaugh, R.T., Oak Ridge National Laboratory, ORNL/TM-2004/185, Sept. 2004, that discusses MG2 motor performance. According to 'Fig. 13. Measured back emfs versus speed' it looks like ~1,500 rpm, the back EMF matches the traction battery voltage.
    To dump energy into the traction battery, the voltage would have to be boosted up to traction battery voltage. Worse, the amount of energy saved is the product of the current and voltage. To keep the energy savings constant, the current from the motor has to increase and higher currents generate more waste heat ... we call it 'I-squared R loss.'
    I've got to collect more data about the braking anomaly but I'll try to work up the energy numbers later today. But the simple answer is there is a point where the only way MG2 can continue to slow the car is to run it as a motor going in reverse.
    2 people like this.
  12. efusco
    19,891
    1,192
    Nixa, MO
    Thanks Bob, again, I think that clearly explains the cut out below 7mph. But what about the cut outs at 30-40mph when slowing and hitting a bump as highlighted by the recent recall?
  13. bwilson4web
    15,511
    I don't know, yet. I was only able to reproduce the problem Friday morning, the second time I was testing the X6-2 accelerometer.
    Fortunately, some of the 2010 users have reported being able to reproduce the problem frequently and I'll be sending my X6-1A accelerometer out on Monday ... after doing another test this afternoon with both units. The streets are dry so I don't expect to see the anomaly ... but that is why experiments are important.
    I've got some nice speed bumps in the neighborhood that I can hit at 30-40 mph. So I'll try them too.
  14. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    From the Gen II talk years back it seemed to be an attempt to protect the transaxle by Toyota. Since MG2 and the drive wheels are directly connected to the PSD, if there were any large difference in wheel spin between left/right, the drive wheel reduction gear might somehow overspeed the ring gear and tear up the PSD. Nothing electrical about it. The Prius always readies the friction brakes when regen flips out, certainly when the traction control does it since the ABS ECU has to tell the TRAC ECU the speed difference. Toyota has probably done this in a very conservative manner to protect the PSD, and will now whittle down the margin of safety to protect the PSD in order to satisfy the new demographic of Prius drivers who can't grasp this car might behave a bit different than their 10 year old chevy.
    Wayne
    3 people like this.
  15. FireEngineer
    1,247
    124
    Bob, you need something that will affect one wheel, not both. I can induce this rather easy, the passenger side wheel seems best. Just take a decent bump or pothole at 25-30MPH with your foot on the brake pedal and the HSI indicating about half-full regen capacity.
    Wayne
  16. David Beale
    5,963
    1,981
    Edmonton Alberta
    The higher speed regen shutoff when a bump is encountered can be explained. I just don't know if it's the -right- explanation. ;)
    Consider what would happen if you -didn't- shut off regen when the wheel hops. Regen adds a large drag to the wheels. The wheel would stop spinning very quickly, perhaps even before it regained the road contact. So it would reach the road at 0 RPM and would squeal or chirp (think aircraft landing). Now -THAT- would get people complaining! It would also jerk the steering wheel and car.
    I'm not certain exactly -what- triggers the regen shutoff. As I've commented in other posts, it "feels" to me that it's a shock to the chassis, not delta wheel rotation rate. But that is just the feeling. I have no data. I also have not experienced in my GII the cutoff at higher speed, only at low speed approaching a stop. Oh, and on a gravel road on "washboard". Now -THAT- was interesting! BTW, that was not a Prius only experience. Most vehicles loose some control over washboard. Pesky physics in action. ;)
  17. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    I missed this thread when it was first posted; sorry for the delay.
    As pointed out above, the low speed cutout is simply a matter of physics. The MG isn't spinning fast enough to do any good, so a transition to friction braking is necessary.
    As for the higher speed transition, I believe this is done to avoid shock loading the HSD. Sudden loss of traction also implies suddenly regaining traction. It's the suddenly gaining traction that is worrisome. Suddenly reloading the HSD comes with three potential problems: 1) Mechanical shock load, 2) Mechanical overspeed, and 3) Electrical spikes.
    Shock loading the HSD could break mechanical parts. The gearing on a Prius is more complex than on the Tesla, and is probably more delicate. Likewise the Tesla has a more powerful inverter and battery system which will most likely better stand up to electrical spikes caused by sudden changes in the MG (dv/dt issues). Finally, there is always the issue of over-spinning MG1. Very quick changes allow little time for the control system to respond, and inertial limits physical response times.
    Tom
  18. hitechboy
    hitechboy New Member
    128
    Toronto, Canada
    There are some answers here:
    http://priuschat.com/forums/gen-iii...-question-about-regenerative-brake-prius.html
  19. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    Making some speculation here:
    Could it be a way for the HSD to avoid dealing with voltages/currents higher than what it can handle? Once the energy is converted from kinetic to electrical, it needs to be converted to chemical energy, that may, in some condition, not happen quickly enough. Wouldn't the inverter take a hit then? Having some kind of huge resistor to dissipate energy could be a solution; preventing such a condition by not using regenerative breaking might be an easier one?
  20. cthindi
    cthindi Member
    177
    85
    Connecticut
    May be the reason to cutoff regeneration could be to prevent shock or Jerk due to additional braking force provided by frictional brakes.
    But then frictional brakes could simply be slowly engaged, unless brake pedal is fully depressed. There should be no reason to cut off regeneration.
    I feel from the loss of braking issue from my own experience, that this does not happen when switching between Frictional and regeneration happens. But rather related to loss of traction for front wheels due to bump or slippery surface, since regenerative braking, unlike frictional braking, happens only with front wheels.
    I had put my thoughts in another post here.
    The http://priuschat.com/forums/gen-iii...easons-braking-loss-possible-way-resolve.html
