Socket size for sparks plug?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Luna3, Jul 4, 2016.
Tags:
  1. Luna3
    Luna3 Junior Member
    Dorloo, NY
    Happy 4th all!
    My fresh set of NGKs were delivered yesterday and I dug around the tool box for a plug socket. Hmmm. I've poked around here and 9/16 seems to be the needed size. But I put a wrench of the plug and 14mm appears to be the number.
    Are the OEM Denso plugs 9/16 and NGK 14mm? I know there's a hair's difference in size, but can anybody confirm? A 14mm socket might run around 20 bucks...
  2. Kenny94945
    Kenny94945 Active Member
    780
    397
    Sausalito
    2016 Prius v wagon
    Not confirm...I believe they are 14 mm.
    Yet, IMO....the right tool for the job. A specific spark plug socket is best for your tool box. Ever break/ crack the porcelain of a plug without the right tool?
    Have fun with your project.
  3. Luna3
    Luna3 Junior Member
    Dorloo, NY
    You know it, especially plugs that are $10 each!
  4. Patrick Wong
    18,200
    6,472
    9/16" = 0.5625 inch
    14 mm = 0.551 inch
    The difference is 2%. The correct size is 14 mm for either Denso or NGK. However if you have a 9/16" spark plug socket, you can use it.
    If you don't have a spark plug socket with the rubber lining, then it would be a good idea to buy a 14 mm spark plug socket.
    Fostel likes this.
  5. Mendel Leisk
    38,654
    I used 9/16" ok. Good to know 14mm is the kosher size though, slightly snugger.
    I bought a decent set of swivel sockets through Princess Auto a while back, for around $20, since I didn't have 9/16".
    #5 Mendel Leisk, Jul 4, 2016
    Fostel likes this.
  6. Luna3
    Luna3 Junior Member
    Dorloo, NY
    I was at first a bit confused...and now I am not. Between the bike, three vehicles, two garden tractors, a weed wacker, and an ice drill, you would think I'd have a complete set of plug sockets...nope, just a couple of rusty junkers in the tool chest. Maybe a magnetic set would be trick.
  7. Mendel Leisk
    38,654
    Rubber inserts that grip the plug are the norm, work good. One of those telescoping magnetic grabbers might help, though if the plug dropped off it could be bad: bend the electrode.
  8. ChapmanF
    15,487
    Well, the way it seems to me as I look back is, I spent more than the first half of my life with one spark plug socket that seemed to work on everything I ever took apart. I think I was 32 when I first bought a vehicle that made me go buy a 5/8" plug socket, so then I had two, and that kind of annoyed me.
    And now here I am, upgrading from one generation to another of the same dagnabbed car model, and having to go buy yet another spark plug socket. What'll they think of next? :)
    By the way, anybody know whether the spark plug well is wide enough for a 5/8" socket to fit down? The reason I ask (knowing the proper spark plug socket is smaller than that) is that this smaller M12 spark plug thread doesn't match the hose on my leakdown tester. There's an adapter that comes with the hose, but that has a 5/8" hex. In case I ever get the situation where my hose unscrews leaving the adapter down there, I'd need a 5/8" socket to get it out, which would be no fun if the socket won't fit.
    -Chap
  9. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Car batteries with skinny non-standard (at least in the US) battery terminals? Cooling systems without radiator caps?
  10. Fostel
    Fostel Member
    87
    25
    London
    Excel
    Will this OEMTOOLS 22891 3/8 do the trick?
    or Magnetic Neiko 02292A 3/8 Inch?
    Thanks!
    #10 Fostel, Mar 31, 2019
  11. Creliandobi
    Creliandobi New Member
    South Carolina
    A 5/8 will indeed fit down the well for the spark plugs -- I attempted to use a 5/8 spark plug socket this weekend, but to no avail as they needed a 9/16 for those I purchased.
  12. Mendel Leisk
    38,654
    I see 9/16" converts to 14.2875 mm. I used 9/16", no problems, but if you're shopping and can find a 14 mm spark plug socket (has the rubber insert to grip the plug) that might be a preferable.
  13. lunacyworks
    lunacyworks Member
    114
    SF Bay Area
    Check the manufactures site, the thread is 14mm not socket size, the socket will be 9/16, [5/8] or 16mm but not 14mm.
  14. lunacyworks
    lunacyworks Member
    114
    SF Bay Area
    This is incorrect 14mm is thread! Not socket size. please remove this post to avoid future confusion.
  15. Patrick Wong
    18,200
    6,472
    This is a G3 thread, not G2. My copy of the factory repair manual says 14 mm socket, for G3 Prius. The Denso website indicates the hex size is 14.3 mm for the SC20HR11 iridium spark plug.
    #15 Patrick Wong, Nov 17, 2019
    Grit likes this.
  16. iskoos
    iskoos Active Member
    401
    246
    Orlando, FL
    Wow... Seems all of the elderly threads are being resurrected due the Spark Plug socket size confusion:)
    I still stand behind what I have said and the correct socket size IS (MUST BE) 14mm, NOT 9/16"
    And with that said 9/16" should work since it is about 0.2mm bigger.
    If the 9/16" were to be the correct size, then 14mm would have NOT worked because it is smaller. I have a 14mm spark plug socket and it fits the OEM Denso plugs perfectly well (Snug fit, NO play). If it wouldn't have fit, then I would have agreed that the correct size was 9/16"
    So till someone explains to me how this is happening, I will continue to argue that the 14mm IS the correct size 9/16" being the substitute.
    And this is all for GEN3 Prius:)
    Patrick Wong likes this.
  17. Mendel Leisk
    38,654
    There's a lunatic stirring things up too...
    Grit and NutzAboutBolts like this.
  18. Grit
    Grit Senior Member
    6,141
    4,055
    Wilkes Land
    One person is only confused. Info here was correct.
    NutzAboutBolts likes this.
  19. iskoos
    401
    246
    Orlando, FL
    I hope this wasn't referring to me. Kind of rude...
  20. Mendel Leisk
    38,654
    Nonono: there's one feller with "lunatic" in is name, reviving every sparkplug thread going.
    The Critic likes this.
