Soft Clicking/Clanging From Under Prius At Low Speed??
Discussion in 'Gen 2 Prius Main Forum' started by Grocked, Jun 17, 2008.
  1. Grocked
    Grocked Green Patriot
    71
    Los Angeles
    I only notice this while driving at very low speeds around 5mph. My Prius is only two months old and I've been noticing this noise since I purchased it. It's a light clicking/clanging coming from under the car. The noise sounds like it's coming from the driver's side wheel. The noise is not noticeable when driving at normal speeds. It is easily audible when the car is driving very slowly 3-5mph on battery power. Very strange! Any advice would be appreciated. The car has been perfect except for this little clicking noise at very low speed. The clicking/clanging noise is coming from inside the wheel well or under the car almost like the sound of something in your bicycle spokes. At some point I remember people talking about this noise happening in the newer Prius's but I can't remember... Thanks PC!
  2. wchardin
    wchardin Senior Member
    2,055
    Nashville, TN
    I would check your tire for a screw or nail, you might have sometime stuck in your tire. That has happened to me more than I would like to admit. Let us know if you find anything.
  3. Grocked
    71
    Los Angeles
    Thanks for the advice. No, it's definitely not something stuck on the tire. That happens all the time and it's usually just a large pebble. The clicking/clanging noise is coming from inside the wheel well or under the car almost like the sound of something in your bicycle spokes. At some point I remember people talking about this noise happening in the newer Prius's but I can't remember...
  4. Bob64
    1,540
    92
    Virginia
    rotate the tires and see if the sound still seems to come from the front side. If it does/doesn't, then you'll have narrowed down the problem a bit.
    Perhaps check your brake rotors or cv joints next?
  5. problemchild
    problemchild New Member
    429
    36
    I hear the same thing on my 08. Its random at slow speeds and usually while Im turning with the windows down so that I am able to hear it. My first thought was it sounds like a CV joint going bad.
  6. Grocked
    71
    Los Angeles
    Yes!! Thank you, yes that's it... You can only hear it with the windows down at slow speeds. It's totally random. Sometimes you don't hear it. What do you think it is?! I've heard others reporting something similar. I'm guessing it might not be anything to worry about but WHAT is it???
  7. a_gray_prius
    2,927
    782
    IL
    I hear a whir for a few seconds on my 4-month old sometimes right after the engine shuts off (coming from the driver's side front wheel area). I assumed it was some kind of pump or motor running to ready the engine for re-ignition (if necessary).
  8. Grocked
    71
    Los Angeles
    That's not it. The sound is not a whir and does not occur while the engine is off, only while driving slowly. problem child knows exactly what I'm talking about. What you are describing is normal and is covered in the manual.
  9. Patrick Wong
    18,200
    6,472
    If, like problemchild, you notice the noise only when making a turn, then I agree that a noisy CV joint is the most likely cause.
    If this bugs you, and the problem happens enough so that you can demonstrate the noise to your dealer's service writer, then I suggest that you let the dealer tech figure it out.
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    That one is the coolant transfer pump, which saves hot coolant in a thermos bottle for the next restart.
    The clicking sound could be the brake accumulator pump. Is it sort of a buzzing or ratcheting sound, which goes in short bursts of about three seconds duration?
    Tom
  11. Grocked
    71
    Los Angeles
    The noise has nothing to do with turning. It happens while the car is going straight at very low speeds.
  12. richard schumacher
    7,663
    1,038
    United States
    Is it always continuously present when going straight at low speeds? At what speed does it stop? If not always present, when it does happen how long does it last?
  13. Grocked
    71
    Los Angeles
    Richard,
    Thank you for your concern. No, it does not happen all the time when going slow. Seems to happen right after turning the car on. I can only hear it with the window open while going at a crawl with the engine off. Sounds like a clanging/clicking inside the wheel. The clicking gets faster when I speed up and gets slower when I slow down. It's like the sound of something in your bicycle spokes. When I start to accelerate to normal driving speed it is no longer audible and doesn't seem to affect normal driving. Like I mentioned, it's sporadic but seems to occur more when I first start the car and drive slowly. It's like there's something inside the driver's side wheel because the clicking noise sounds like it's reverberating inside of something metal giving it a "clanging" quality. It's audible while going straight or turning at low speeds. Let me know what you think. Thank you!
  14. pappyt
    pappyt Junior Member
    59
    i here a noise on my 08 touring coming up my driveway, like a loose muffler sound or a stick hitting a can sort of sound, hard to describe . but it only has 228 miles on it and my 07 coming up the driveway does not make the sound? i have gotten under it it and shook the exhaust system, but it does not make a sound at all:confused:
  15. Grocked
    71
    Los Angeles
    Holy 08 Prius weirdness!! What is going on here? Maybe there's something loose inside the tire tube? At this point I'm stumped. I hear folks describing similar sounds on the new Prius but no explanation... Someone will figure this out.
  16. Patrick Wong
    18,200
    6,472
    Perhaps the left front wheel bearing is slightly out of spec, so that when the parts are cold the bearing makes noise at low speed.
    Or there could be a problem with the left front tire; perhaps you could rotate that tire with the left rear tire and see if the sound moves to the back of the car or not.
  17. Kablooie
    Kablooie Member
    273
    La Canada
    Sounds to me like a Toyota worker that fell into the undercarriage and the noise you hear is his ghostly skeleton banging on the frame.
  18. richard schumacher
    7,663
    1,038
    United States
    Anything like this symptom that could be related to the suspension or steering should be checked out ASAP. If you're lucky it will be some object inside the tire, so when you take it in have them remove that wheel first and roll it around and shake it to see whether anything rattles inside.
  19. Grocked
    71
    Los Angeles
    Possible Explanation!
    The hub caps on the new Prius are made of a polymer/plastic material and make a similar crunching sound when I push them with my hands. Maybe the caps are just making the noise at low speeds(that's the only time it's audible). Did Toyota change the design of the hubcaps in 08? Maybe this is what's causing the clicking at low speeds?
  20. richard schumacher
    7,663
    1,038
    United States
    Well, then: pull off the trim rings one at a time and see what happens.
