Software mod to allow while-moving Nav and Phone.
Discussion in 'Gen 3 Prius Audio and Electronics' started by garygid, Nov 3, 2009.
  1. garygid
    garygid Senior Member - Blizzard Pearl
    379
    23
    Orange County, CA
    On the 8.1 (or 9.1) NavDVD there are many files (using about 7.5 GB of space).
    One can load these files onto a PC. Then, one could look at the "control" files
    to find a hidden setting, option, or maybe even a "patch" that would defeat
    the while-moving" inhibitions?
    Has anybody tried this "software" approach?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Have at it. You can be the first.
    Tom
  3. trashcan
    trashcan Junior Member
    26
    San Jose
    I just made a hybrid DVD with the 5.1 loading.kwi. Haven't tried to reload the loading.kwi yet but the new hybrid DVD map portion is working fine.
  4. RodJo
    RodJo Member
    423
    56
    Boston
  5. rachaelseven
    rachaelseven New Member
    616
    212
    Adams, MA
    I had no luck with the hybrid disk when I tried it... the 5.1 loading.kwi file did not seem to work with the Gen6 nav unit, as far as I could tell :(
    That's not to say that someone couldn't hack the file and remove the lockout, but disassembling and hacking the code is way beyond me.
  6. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
  7. trashcan
    26
    San Jose
    No luck with the hybrid disc..the 5.1 loading.kwi will not load when doing the fuse trick. I also made a backup copy of the 9.1 DVD and the backup one is loading fine. I am gonna mess around with the backup copy and see what it does.
  8. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    makign a backup copy today, we'll see what I can do with it.
  9. karl_boekelheide
    karl_boekelheide New Member
    I assume you found the same thing I did that unless you remove power from the DVD unit you don't actually get the 5.1 loaded. Consequently you don't get the override ability back. For me when I got the 5.1 code loaded (LOADING.KWI) I could override but the mapping is all but useless. Points of interest, addresses - all the useful stuff - is broken.
    If you have gotten it to work, I and thousands of others would like to know how. I'll probably go back to using the 5.1. It's better to have an old map I can use rather than a new map that's locked in a box on your dash board. To see the rage visit ToyotaOverride.com
  10. AndyZaa
    AndyZaa Junior Member
    33
    16
    New Brunswick, NJ
    I agree - we need folks with "good" loading.kwi files that enable bypass to post the file particulars (size, date) for various configurations (gen 4, 5, 6).
