Software update for Prius 2015 model.
Discussion in 'Gen 3 Prius Technical Discussion' started by IloveJesus1234, Sep 12, 2016.
  1. IloveJesus1234
    IloveJesus1234 Junior Member
    16
    Hello, so I was wondering if there are any software updates for the Prius 2015 model? I heard of something called Etune, but my car wasn't built with apps at all. Its the type of prius that has this screen with a lack of apps if anything....http://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/jCwAAOSwMsVXjOz-/$_1.JPG.....notice how the dash doesn't show the name "apps" on it.....so yea that is basically it.....I heard you can insert a usb into the car and it will update, does this apply for my model? I really wanna update my car but idk if I can, mind giving me some tips guys?
  2. IloveJesus1234
    16
    51,154
    no, no updates. entune is the entertainment system you use with your phone. i thad (has) a lot of glitches, and they keep coming out with new versions, but they don't help much. kind of the microsoft of car audio.
  4. IloveJesus1234
    16
    Yea, my car was never built was entune, it just had a standard computer system...are there any non-entune updates?
  5. bisco
    51,154
    nope, toyota doesn't do that sort of thing. sometimes, if there is a safety issue, you can bring it in for a software flash update, but nothing on the 2015's iirc.
    you can plug your vin into the owners website for recall info. if you've owned it since new, you would have received a notice.
  6. ChapmanF
    17,347
    You might want to edit your first post ... it looks like you tried to supply an image link and then say ".....notice how the dash doesn't show ..." but the way it is now, that first ".....notice" ended up as part of the image link, so the image doesn't show. When I chopped that off so the image link just ends in .JPG then I was able to pull the image up.
    Still, the image is too small for me to read the faceplate number under the bottom right corner of the screen.
    The updates to headunits aren't generally treated as recalls ... it would only be a recall if for some reason the old software was considered dangerous. Otherwise it's just an update, and you won't necessarily be notified of it.
    If you sign in over at techinfo.toyota.com (it's a $15 hit for two full days of browsing), click the TIS tab up top, enter your model and year, then click the TT/SB tab (technical tips and service bulletins) you can find if there are any bulletins regarding an update to your headunit. (You can also find many other service bulletins about your car, some of which may be of interest to you even if they have nothing to do with your headunit.)
    There's also a QTG tab (for Quick Technical Guides) and one of those, QT616A, is all about how to recognize which unit you have, and what capabilities it does or doesn't have, by photo and model year.
    -Chap
  7. IloveJesus1234
    16
    I understand, but is there a free, way you could suggest me for seeing if there are any downloads for my headunit? My headunit number for my radio is this....57031
  8. IloveJesus1234
    16
  9. bisco
    51,154
    why is the model not available?
  10. IloveJesus1234
    16
    What does "iirc" mean?
  11. IloveJesus1234
    16
    what do you mean, can you re word your reply
  12. bisco
    51,154
    iirc = if i recall correctly.
    in your avatar, your model says n/a.
  13. IloveJesus1234
    16
    I didn't care too much to look it up for this forum....Idk what model it is but lets just say its a 2015 prius hatchback non plug-in.
  14. bisco
    51,154
    the reason i mention it is that the head unit comes by model. i'mguessing you have a 2, but not sure. i didn't realize they even made a screen without apps.
  15. ChapmanF
    17,347
    Seems to me there was a thing called "Display Audio" and another thing called "Premium Display Audio with Navigation and EntuneĀ®". Seems like the 57031 is the first thing.
    If the difference between $15 and free is critical, asking your dealer is probably the most straightforward option; if it turns out there is an update, you may need the dealer to install it anyway.
    The only unknown in asking the dealer is whether your question actually gets to someone who knows how to find the answer.
    If you had a headunit with nav, I'd probably recommend waiting for November or so, as that seems to be when the latest updates will come out. I don't know whether a similar schedule applies to the non-nav units (or whether there are any updates at all).
    -Chap
  16. IloveJesus1234
    16
    Yea I don't know really, but yea if anything mine doesn't have apps, and is similar to a standard computerized headunit.
  17. IloveJesus1234
    16
    Its non nav if anything......so yea you don't know of any websites I could do it myself for free? Like the toyota website for example?.....its a 2015 model btw.
  18. bisco
    51,154
    try post #5.
