software update?
Discussion in 'Gen 2 Prius Main Forum' started by SarahfromMA, Dec 15, 2016.
  1. SarahfromMA
    SarahfromMA Junior Member
    Northampton, MA
    Hello!
    New here. My mechanic charged $97 to "update ECM calibration files"
    Anyone know what that means or why it is necessary?
    We brought it in for a check engine light and it sounds like the gas tank emissions sensor needs to be replaced.
    49,516
    welcome! sounds like he needed to update the amount of cash in his wallet.:p
    so, he hasn't replaced the sensor? ask him for the trouble codes he pulled and post them here.
    how many miles are on your car?
    sometimes, the check engine light is just a loose gas cap.
    #2 bisco, Dec 15, 2016
    Prodigyplace likes this.
  3. SarahfromMA
    Northampton, MA
    Thanks for replying!
    Somehow he got the check engine light to go off, but said I needed to stop by again.
    Will keep an eye on the gas tank cover-thank you.
    The car has 155k miles on it.
    He also said to replace the gas sensor is very involved and you have to take the gas tank out.
    49,516
    is he a hybrid specialist?
  5. SarahfromMA
    Northampton, MA
    It's Abba motors in Florence. Think they were recommended here and he said they've been doing hybrids sinc '99.
    However, I didn't authorize the software update (and am in a financial crunch this month) so I may not go back to them.
  6. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    You can clear the codes with an ODB2 adapter. Anyone can do it. Doesn't fix anything. Whatever triggered it will eventually trigger it again.
  7. SarahfromMA
    Northampton, MA
    Aha.
    So if my inspection is due next month, better go while the sensor is still off?
  8. ChapmanF
    15,697
    The ECM is the Engine Control Module, one of the several computers in the car. A "calibration file" is a bunch of tuning parameters Toyota develops and loads into the ECM. Sometimes they do identify ways to improve the calibration and improve how the engine runs, and they release updated calibration files.
    If you have a laptop and Techstream (lots of posts in these forums about using that software, needs a little dongle from the laptop to plug into the car, some are less than $30), you can even check what calibration files you currently have (a geeky thing to do, maybe, but an easy way to confirm what your mechanic actually did).
    For example, my Gen 3 engine calibration is currently 34715200, from which I can tell that no one has ever done the EGR system warranty repair on my car yet, because if they had, it would be at least 34715700.
    Your mechanic might be able to tell you which calibration he loaded, and whether there was a service bulletin saying he should update to that version, and what issues it said it might solve.
    Can you get him to tell you what the actual trouble code(s) was/were indicating the issue with the "gas tank emissions sensor"? That information might also help pin down which sensor he means. I'll guess he means the vapor pressure sensor, and yeah, the picture in the New Car Features Manual shows it on top of the tank, so the tank might have to come out to get to it.
    But there's a whole section in the repair manual on how to pin down why pressure readings might be off, before being sure the sensor is at fault.
    -Chap
  9. bisco
    49,516
    when you go for an inspection these days, all they do is plug in and read the history. so, it doesn't matter whether you go with the light on or off.
    if the calibration fixed it, you'll pass. if the computer says you need a new sensor, you'll fail.
  10. SarahfromMA
    Northampton, MA
    Got it! Thanks so much Chap and Bisco!
  11. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    If it's truly fixed.
    My understanding is that if the codes were merely cleared then the emissions status will be in an indeterminate state until the car/engine has been run far/long enough for the computer to be sure any (now cleared) conditions are not obviously still present. Until then, those sensors won't report PASS even if the CEL is off.
  12. SarahfromMA
    Northampton, MA
    That makes sense.
    For the gas cap, would it just need to be turned more tightly, or perhaps replaced?
  13. wrprice
    415
    308
    Houston, TX
    Four Touring
    Could be either. Easiest to know if you're the only one who ever touches the filler cap. A loose cap is obvious. If it was tight but throwing codes it could be defective.
    The other thing about gas cap codes is that they don't immediately clear the CEL when you fix it. The car needs to go through a number of driving cycles after the fix before it clears. You can force clear, but then see my prior post.
