Solar/AC Fan making screeching sound
Discussion in 'Gen 3 Prius Technical Discussion' started by Gilbert, Sep 3, 2015.
  1. Gilbert
    Gilbert Member
    255
    I'm assuming the blower on my 2012 is most likely starting to fail...
    called dealer and its special order at $170... I'm not paying that for a blower. found some on amazon for about $80 and says its fits 2012 year model.. is this hard to install?
  2. afob3
    afob3 Member
    124
    40
    TN
    Unsure on the install. However, are you sure a leaf or other debris hasn't snuck past the cabin filter? This happened on a previous car of mine and pulling the filter behind the glovebox & clearing the crap out got rid of the sound.
    49,418
    is the solar fan in the glovebox?
  4. afob3
    afob3 Member
    124
    40
    TN
    good question... I'm assuming so since it draws air in from near the passenger wiper and blows it through the same vents. Without that filter in-line theres no telling what it would suck in while unattended.
  5. bisco
    49,418
    and blows the hot air out through the open sunroof?
  6. Gilbert
    Gilbert Member
    255
    I'm pretty sure the solar fan is the same one as the AC uses. produces the same noise when passive solar ventilation is active. I think its under the glove box but not completely sure. I'm just gonna wait until I get the replacement to try and check if I can easily replace it.
