Solar fan working correctly?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by wxboy61, May 12, 2011.
  1. wxboy61
    wxboy61 New Member
    MA
    Under certain conditions the solar fan in my car will come on for a couple of seconds and then shut off and continue to do this for a while. Is this normal behavior? I'm assuming it is but I'm wondering what causes it. Is the temperature in the car borderline so it's just giving a short burst of outside air now and then? Is the voltage coming from the panel marginal and there isn't enough juice to keep it spinning so it stops? Just curious about this so maybe someone can shed some light on what's happening. Thanks.
  2. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    I can't tell you why that happens, but mine does that too, so I guess it's normal.
    More fun is the 'groaning' noise often heard when it's not quite bright (or warm?) enough to need to run the fan, but the switch is on so the system is active.
  3. Buzzhead
    Buzzhead Non-Interference w/ devel of pre-Warp civs
    145
    53
    Chelmsford, MA
    Same for me, so I call it normal. I refer to the sound as "flatulence" (actually, I use a more anglo-saxon term).
