Solar mission: designed life 4 years, served 17
Discussion in 'Environmental Discussion' started by bwilson4web, Mar 21, 2020.
  1. bwilson4web
    15,513
    Source: Solar energy tracker powers down after 17 years
    After nearly two decades, the Sun has set for NASA's SOlar Radiation and Climate Experiment (SORCE), a mission that continued and advanced the agency's 40-year record of measuring solar irradiance and studying its influence on Earth's climate.
    SORCE's TSI values were slightly but significantly lower than those measured by previous missions. This was not an error—its Total Irradiance Monitor was ten times more accurate than previous instruments. This improved solar irradiance inputs into the Earth climate and weather models from what was previously available.
    "The big surprise with TSI was that the amount of irradiance it measured was 4.6 watts per square meter less than what was expected," said Tom Woods, SORCE's principal investigator and senior research associate at the University of Colorado's Laboratory for Atmospheric and Space Physics (LASP) in Boulder, Colorado. "That started a whole scientific discussion and the development of a new calibration laboratory for TSI instruments. It turned out that the TIM was correct, and all the past irradiance measurements were erroneously high."
    GOOD JOB . . . SOURCE team!
  2. hill
    8,159
    also .... Didn't some agency send a little RC car - that ran around mars for way more years - than they ever anticipated? Good to know that we can still do things reliably.
    fuzzy1 and Trollbait like this.
  3. fuzzy1
    10,166
    "Opportunity" had a design objective of 90 days and 1000 meters. It went 15 years and 28 miles before dying of hypothermia and sunlight deprivation while trying to hibernate through a major dust storm.
  4. bwilson4web
    15,513
    I had the computer network task to connect the control center in San Diego with the NASA mission network demarcation in Jet Propulsion Labs. The requirements:
    • lowest possible cost (it was only going to last 90 days)
    • 45 mbs primary control, voice, and science
    • 1.5 mbs alternate routing for control, voice, and science
    • Four, 4-wire voice circuits at each end
    • Plain Old Telephone dial-up line for redundant access to San Diego routers and switch
    • JPL campus network fiber circuit between carrier and mission network buildings
    My solution installed the smallest possible routers with a pair, of dual, 4-wire audio controllers using a lash-up, voice-over-IP link (a first for any NASA network.) It used Quality of Service queuing so network management, voice and mission control traffic had priority over both the 45 mbs and 1.5 mbs circuits. Any unused bandwidth could be used by general mission data, e-mail, and web access.
    After two years, some of the routers had reached end-of-life. So it was re-engineered with independent, 45 mbs network links and modern hardware. Some of the "network security" staff added requirements so they could wire-tap all traffic. Another two years and the NASA Mission voice team switched from 4-wire, audio telephony to native Voice-Over-IP.
    I did it first for a fraction of the cost meeting both redundancy and performance specs. I was glad that the two Mars rovers lasted as long as they did and delivered real science about Mars. But this pattern of extending mission life is the unsung heroics of NASA Missions.
    Hubble still delivers useful science even though inertial wheels have all but failed. Other science spacecraft often extend until the last bit of station pointing or control systems fail. The record are the Voyager I and II missions that have left our Solar system. The only physical evidence of intelligent life from our planet.
    fuzzy1 likes this.
  5. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Not surprised.
    Engineers always overbuild with a safety margin, likely much more so for space missions. But they are always conservative on their public promises as people usually remember the failures much more than the successes.
    Underpromise, but overbuild.
    3PriusMike likes this.
  6. hill
    8,159
    safer to say - they often over bill as opposed to always.
    Not to beat the point to death, because there are tons of YouTube videos older & newer that display amazing lack of considerations . Even NASA.
    My mom worked with North American Rockwell when they were developing the Apollo capsules with WAY too much oxygen. Next thing you know ..... faulry wiring & astronauts are cremated.
    Regulations: they are written in blood
    bwilson4web likes this.
