Solar Moonroof and NAV quesions from Newbie
Discussion in 'Gen 3 Prius Main Forum' started by Nerdalert, Apr 13, 2012.
  1. Nerdalert
    Nerdalert Junior Member
    25
    I have had my Prius for about 3 weeks now, still getting used to it, but loving it.
    Here are two quick questions
    1.) The fan for the solar roof (on the left) i can't tell if it's on or off. i don't see an indicator. I want it to be on all of the time. How do i do that?
    2) is there any quick way to turn off the nav? say when you are close to a destination, and know where you are. seems like there would be a stop nav button on the main screen, but i have to go back two levels to pause. I want to live!
    thanks
  2. jdcowboy
    jdcowboy New Member
    Moorpark, CA
    Not sure about the first question. I have the same question!
    For the NAV, you have to tell it to delete the destination to get it to stop.
  3. Buzzhead
    Buzzhead Non-Interference w/ devel of pre-Warp civs
    151
    59
    Chelmsford, MA
    In the "on" position, the switch is detented inward about an eighth of an inch. You can feel it easier than seeing it as you depress the switch. One person had put some red tape on the console frame just below the switch to make it easier to see that it was on.
    Don't forget, in order for it to work, you have to select the "on" position before you shut the car down.
    Congratulations on joining the "Airhead Armada"
  4. Nerdalert
    25
    Thanks to you both, I will confess to being blonde :rockon:
  5. mathan
    mathan Junior Member
    47
    Toronto
    I'm curious - does everyone here just leave the fan turned on here, during the summer or are people just using it when parked outside and during the afternoon?
    I'm preparing for when I pick up our new car tomorrow with the mooonroof. :)
  6. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    When the fan is on you can hear it when you enter the car. In fact, just walk up to the windshield area and you can hear the fans sucking air into the car. It has not been hot here yet but even with outside temps in the 60s the system will start. That means the interior temp has rose above the 65degree setting. I really like the system!
  7. Tideland Prius
    16,445
    I leave it on all summer and only turn it off if it's dusty or someone's BBQ'ing nearby.
  8. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    It's a two position switch. Slightly recessed when it's on.
  9. Tideland Prius
    16,445
    1. Just press the SPVS button located to the left of the steering wheel. You can leave it depressed all year if you want.
    2. As in cancel the destination?
    Opt 1.
    Press ROUTE --> Delete --> (If it's the only destination) Yes.
    Opt 2.
    Press the VOICE button, after the beep say "Delete all destinations". It will ask "delete all destinations? Say yes or say cancel to end voice recognition without deleting destinations". Say "Yes".
