Solar panel charging...
Discussion in 'Prime Main Forum (2017-2022)' started by Digloo2, Jun 3, 2019.
  1. Digloo2
    Digloo2 Active Member
    124
    132
    Phoenix, AZ
    Has anybody looked into what it would take to get a couple of solar panels, batteries, and inverter just to charge a Prius Prime at night (L1 or L2)?
    I'm getting solar panels installed, but without a battery (they offered one, but it's now back-ordered for a year).
    It costs me about $30/mo to charge the Prius Prime.
    Solar won't drop that at all if I end up charging it at night w/o a battery. (Well, maybe $1/mo.)
    So I'm curious about a dedicated setup just for the car.
    Sezy likes this.
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    At a $30/month savings, you will have a very long payback period. The temporary storage battery will likely have to at least 50% bigger than the car's traction battery to start. Then you need to size the solar arrays to fully charge that on the shortest day of the year if you want this to work year round.
    I would just pay the $30/month and be done with it and skip the storage battery.
    Note that if you are pushing solar power to the grid by day that will offset some of your nighttime charging cost. I would think that's more than $1 a month.
  3. Blue-Adept
    Blue-Adept Active Member
    293
    179
    Grand Rapids, Michigan
    2018 Prius Prime
    If your state has a net metering policy inplace you don't need battery storage. Look it up online. You could start small by using Enphase micro inverters if you are handy. They convert power to AC at the panels. Start with four 335watt Panasonic Hit panels. 20 amp 220 breaker. Then build up from there.
    I have 10.275 kwhp installed of solar panels now. Payback time 6.8 years. Then 20 plus years of free power.
    PM me and I will send you a link to see my setup.
    My Prime is a stepping stone to a full EV.
    #3 Blue-Adept, Jun 4, 2019
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    The key here is that you WILL get the full benefit of whatever power your solar array generates.
    It matters none, or very little, WHERE that power is actually consumed.
    Home lights, refrigerator, fans, A/C, going back to the grid or going to the Prius.......same net savings (or nearly).
    Obsessing about getting power directly from the solar array to your Prius will be a HUGE MISTAKE.
    Tightwad77, benagi and MTN like this.
  5. Salamander_King
    Salamander_King Senior Member
    11,013
    8,942
    New England
    If you have net meter like others have suggested, it does not matter if you are charging at night or during a day. As long as your solar panel produce on average more than 6kWh/day of electricity, you are getting free electricity to charge your PRIME. AFAIK, setting up battery storage for solar panel is too expensive currently to be economical.
    Sezy and benagi like this.
  6. Blue-Adept
    293
    179
    2018 Prius Prime
  7. bisco
    51,669
    just use your solar for other things around the house. the expense and headache of trying to accomplish this will far outweigh 30 bucks a month.
    if net metering is a poor financial choice, don't get more panels than you use on average
    Salamander_King likes this.
  8. Digloo2
    124
    132
    Phoenix, AZ
    Great points. The solar company is putting up 16 x 315W panels with micro-inverters on each one.
    The utility company here, APS, allows panels to produce 110% of average annual consumption, or 115% if you have an electric vehicle (the Prime counts).
    With net metering in place, they force you to pay a premium for power between 3-9PM now, at ~20 cents/kWh, and 10 cents/kWh for off-peak hours.
    They say they pay you 11.6 cents per kWh for whatever you push onto the grid.
    In my mind, the best value of a battery is going to be in reducing the cost of power in the summer during peak hours. Is this a good assessment?
    The car is secondary, and probably not worth it by itself.
    (During the summer months, my peak consumption is 30-40 kWh/day due to heavy A/C loads, particularly from noon to 9 or 10PM. With no heat or A/C, my minimum is right around 4.5 kWh/day. When I'm out of town, it's about 2.25 kWh/day (no A/C).)
  9. bisco
    51,669
    what size battery would you need to make an effective dent, something like a tesla power wall?
  10. Digloo2
    124
    132
    Phoenix, AZ
    I do not know. That's what I'm wondering about.
  11. Trollbait
    12,461
    A Powerwall is 6.4kWh, so one will cover a Prime's charging. They are almost $8000 without installation.
    First look for ways of shifting electricity use to peak solar production. I'd try hypermiling the AC. Have it cool down the house below your normal set point before 3pm so it can be shut off during the higher rate. Maybe the same can be done with hot water by using a timer. Some washers and dryers have a timer function to have it start later. Same with ovens, but I'd be hesitant to have one on while away from the house.
  12. sam spade 2
    7,035
    2,801
    2017 Prius c
    I did that in my latest house.
    Turns out it isn't worth the money and minor hassle.
    A modern well insulated water heater runs very little when no water is being used.
    If you have a really OLD electric water heater, your money would be better spent getting a new one.
    I turned mine completely OFF for 3 days while I was gone.
    When I returned the water was still on the high side of warm.
    gggGary likes this.
  13. Digloo2
    124
    132
    Phoenix, AZ
    The home is 1960 vintage, and has block wall construction with no insulation (no drywall) on the inside. This seems ill-advised. I'd be better off adding insulation either inside and/or outside.
    Nope. I can turn my water heater off entirely from mid-June thru mid-September as the cold water alone is almost TOO HOT to bathe in!
    But thanks for the thoughts.
  14. Kenny boy
    Kenny boy New Member
    Binghamton, NY
    2020 Prius Prime
    Why not add a solar panel roof / factory option or engineer one and add it on your own to charge you batteries ... 864482D1-576D-4925-A44C-3F2535321E1F.jpeg
    Rmay635703 likes this.
  15. bisco
    51,669
    great idea! please let us know how it works out (y)
  16. fuzzy1
    10,356
    How many solar miles per day are expected in Dubai? Or in Japan?
    Past proposals just haven't produced enough daily driving range in most climate zones. It has been more efficient and cost effective to put solar modules on a building's roof, plug the car in to the wall to take what it can, then send the rest to the regular power grid.
    Less expensive solar modules, mounted in a better location and aspect, collect more total energy, and all of it gets used by somebody, rather than thrown away when the car doesn't need a recharge.
    #16 fuzzy1, Mar 26, 2020
    gggGary and Trollbait like this.
  17. Rmay635703
    Rmay635703 Senior Member
    2,661
    1,684
    Somewhere in Wisconsin
    2013 Chevy Volt
    I honestly think it would be cheaper /more effective to import a junked Japanese Prime with panel system than what the op is proposing
  18. evpv
    evpv Active Member
    691
    338
    West Coast
    2019 Prius Prime
    It’s only March and my 10 panel home system is already making enough kWh to charge our 2 Primes every day, with extra left over. Should be net zero for the year here in SoCal. $6500 after fed rebate. No battery backup. I like the idea of using the sun to power most of our driving.
    drash and benagi like this.
  19. bisco
    51,669
    can you re mount it onto the roof of your prime?
  20. evpv
    evpv Active Member
    691
    338
    West Coast
    2019 Prius Prime
    I have 2 Primes, so maybe I can mount 5 panels on each, like a sprint car.
