solar panel + prolong charger?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by k1ngn0thing, Mar 13, 2018.
Tags:
  1. k1ngn0thing
    k1ngn0thing Member
    205
    49
    MA
    2016 Prius c
    Has anyone used something like the Prolong charger by Hybrid Automotive in conjunction with 1-200 watts solar to charge the battery while driving, to reduce gas use? Would that rate of charge even make a dent in it? Is it even possible or advisable to have it charged from multiple sources simultaneously like this? I don't expect I'll ever bother doing this, just having some fun.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    No and not advisable.
    qettyz, Prodigyplace and k1ngn0thing like this.
  3. fuzzy1
    10,172
    Mounting the solar system such that its extra weight and air drag don't consume all possible gain, will be difficult.
    qettyz likes this.
  4. k1ngn0thing
    k1ngn0thing Member
    205
    49
    MA
    2016 Prius c
    eh, there are very low-profile flexible solar panels and the edges could be taped so no air gets underneath
  5. MickyMatter
    MickyMatter Active Member
    260
    166
    Germany
    Toyota says, the solar roof of the Prius IV will extend the range up to five kilometers per day.
    That would save me max. 0,3 € per day. Due to the cheaper gas prizes in the US you will save less.
    In the winter the sun has less power. And then the rainy days...
    I think it would last three years for me to save 100 €. Panel and charger and installation will cost much more I think. Don't forget the possibility of an early damage.
    In the summer usually I try to park in the shadow (underground garage or parking house (not sure about the right English words)). With the solar roof I should park in the sun. But then the car would heat up much more and the solar power would feed the A/C. I don't know, but I think the A/C would need additional power.
    It's possible that the disadvantages could dominate both ecologically and economically.
    Cheaper standard panels installed at home could be better, because
    - they can be standard -> cheaper
    - they can be bigger (more surface) -> more power
    - they can be in the sun all day long -> more energy
    - they cause no additional weight/wind resistance to the car -> less consumption
    Pantelis and fuzzy1 like this.
