Solar Panel Weight?
Discussion in 'Gen 3 Prius Main Forum' started by ERiley1, Aug 19, 2009.
  1. ERiley1
    ERiley1 New Member
    Maryland
    I was just curious as to how much the solar roof weighs. I was wondering because I've heard anywhere between 40lbs (in this forum somewhere) and 700lbs (from a salesperson). Also, how much does that added weight effect fuel efficiency. Is it a significant difference? (I'd imagine not but just to make sure :rolleyes:).
  2. nola_Prius
    nola_Prius New Member
    405
    62
    New Orleans
    I don't know how much it weighs exactly, but I guarantee you that it is nowhere near 700 lbs... and NO, it does not alter the fuel efficiency.
  3. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Another well informed sales person. :(
    I don't know either but if it were 700 pounds the 825 passenger and cargo weight limit would be sorely compromised. One 125 pound driver and no other passengers or cargo? I don't think so.
    I suspect the sun/moon roof part of the package is the bulk of the weight.
  4. ERiley1
    ERiley1 New Member
    Maryland
    Yea, I didn't want to trust the guy... especially because he tried to convince me that the II, III, and IV, had 16" tires. He also tried to tell me I couldn't get a bisque interior on the blizzard pearl -_-
  5. PearlthePrius
    PearlthePrius New Member
    Pennsylvania
    I have the solar panel and love it and love the prius. No problems to report yet, everything is working smoothly.
  6. Tideland Prius
    16,615
    Found the answer on the Toyota of Japan website....
    ソーラーパネル付ムーンルーフとソーラーベンチレーションシステム&リモートエアコンシステムを装着した場合は+30kg
    when the solar panel attaching moon roof and the solar ventilation system & the remote air conditioner system are installed, +30kg
    The LED, 17" alloys package add 30kg. Leather, nav, IPA w/ backup camera, DRCC & PCS add another 40kg (more applicable to Canadians than Americans). HDD nav is 10kg (that's a heavy nav!).
  7. fuzzy1
    10,603
    Is there any indication that those of us lacking these options can add some of these weights to our maximum payload?
  8. Tideland Prius
    16,615
    Well i'm curious because the payload applies to all Priuses but as you can see, there's a good weight difference between a base and loaded Prius. E.g. a Prius V w/ ATP is at least 70kg heavier than the base II.
  9. forsaken1111
    forsaken1111 New Member
    Herndon, VA
    Is it possible for someone who owns a Prius V to have the solar roof installed later? Will the dealership do this, if I purchase the assembly?
  10. Tideland Prius
    16,615
    Not that I know of. Dealers won't install anything that isn't a manufacturer accessory.
  11. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    For the metric challenged, 30kg is 66lbs. I had heard 62lbs from some sources, so this is about right.
  12. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    There have been many discussions about this. The real answer is that it weighs about 65 1bs (but I can't find the particular post). I've heard salesmen sayiing it weighs 200-400 lbs, but the one that told you 700 lbs takes the cake! Here's one thread that talks about weight:
    http://priuschat.com/forums/gen-iii-2010-prius-main-forum/61454-solar-roof-mpg.html
  13. xbdude
    xbdude opticat
    168
    North Central Florida
    Back in my motorcycle racing days, we would talk about how we could shed a 1/2-pound here and there on our bikes, thinking that it would make us faster. The sponsor would say that we were riding it, not carrying it. Really, 65 pounds doesn't seem as if it would make much of a difference. Just my two cents . . . . .
    It's just a car that gets extraordinary good mileage. What more can we ask except for a plug-in.
  14. DtEW
    DtEW Active Member
    242
    137
    SF Bay Area, CA
    Whereas 60 pounds makes little-to-no difference when it comes to fuel efficiency, it does make a difference in cornering when almost all of it is located at the highest point of the vehicle. It might potentially have some small effect on braking/acceleration traction as well.
    (The negatives are all about CoG height and weight transfer effects.)
    The easiest demonstration of this is something that many of us already do on a regular basis: bolting a bike rack on top and loading it up with some wares. You'll definitely feel it in the curves.
    I used to love sunroofs/moonroofs, but after developing a creak in it (from chassis flex) in the last car I had and unbolting parts of it in an attempt to to re-tighten it, I had a first-hand experience as to how much mass (100-ish pounds!) it was, and therefore will not consider it in the future for anything except overbuilt luxo-barges well-into the 2-ton range.
    Just my 2 cents, and nothing more.
  15. PriusRos
    1,973
    218
    Rockville, MD
    I love the solar roof. It's still fairly rare to see one on a Prius and they look really neat when opened up. The other advantage is the solar cell ventilation. While it doesn't cool the car, it keeps the interior bearable when the car is parked in the sun on a hot day.
