Solar Plane Successfully Completes Maiden International Flight
Discussion in 'Environmental Discussion' started by Rybold, May 15, 2011.
  1. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    Solar Plane Successfully Completes Maiden International Flight | GreenAnswers
    Keep in mind that the Wright Brothers' first flight only supported one person. Back then, who would have thought a fully-loaded cargo plane could lift off of the ground and fly? This solar plane could just be the beginning; the Kitty Hawk of solar airplanes. Sure, it's not going to go 500mph, but this test plane did carry the weight of an adult human and lithium ion batteries through international flight. If the batteries were reduced down to 10% just for emergencies, these places could fly during daytime with more weight.
  2. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    That was a great accomplishment but the upside is very limited for normal aircraft use. There is only so much solar energy falling on a given area. It will never be a practical replacement for normal aircraft.
    Where a solar powered aircraft really shine (pun intended) is as an unnamed scientific or military data acquisition platform with a loooong loiter time.
  3. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    Solar drones. Small, painted blue on their bellies to visually blend in with the sky and electrically silent.
  4. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    ....as long as oil is cheap.
  5. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Or expensive.
  6. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    What kind of motors did this plane use ?
  7. Rybold
    2,760
    322
    Southern California
    These planes actually have an advantage. This current version uses a clear lexan (think of clear 2L soda bottle material) for it's skin. Since it's lightweight and flies slow, it doesn't need metal sheets; it can remain transparent. No better camouflage in an infinitely changing sky than transparent wings and fuselage. :)
  8. Rstaton
    Rstaton New Member
    60
    Watsonville, CA
    Sounds like Wonder Woman's invisible jet. Except you can't collect solar energy with transparent solar panels.
    As for it being impractical because of limited solar energy, future advances might make it practical. The solar cells right now are not efficient. But future solar panels might put out 3X as much power. Then, design a plane that intentionally has a large surface area facing the sun, and you're onto something!
  9. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    I think for any application moving cargo or people (it works perfectly as a spyplane now, i'm sure they said when they did the night flight that it could stay up indefinitely in the summer months) the solar is a bit of a "nice to have" that extends flight time/reduces battery weight, but it will be heavily battery reliant. I'm fine with that. Make the body out of that material Volvo were testing which has similar properties to high strength steel but also acts as a battery. i flew quite a bit for work last year and didn't like it, i'd have been much happier in an electric plane :)
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Even if the solar panels could be made 100% efficient, they would still lack the necessary power to move a plane at high speed. Solar powered aircraft, by the very nature of energy density, must remain niche vehicles.
    For high speed flight, solar power only works if it is off of the plane, where it is used to generate some sort of high energy density fuel.
    Tom
  11. Rstaton
    Rstaton New Member
    60
    Watsonville, CA
    You're assuming that high speed planes of the future require the same amount of power as today's planes. There is no law that says it takes x power to fly at y speed.
  12. qbee42
    18,058
    3,074
    Northern Michigan
    I assume you are making a joke? The laws governing this are the most basic of all: the laws of physics. Physical law in this area is simple and well understood, and it doesn't allow for high speed flight at those power densities.
    I suppose we could allow for a wholesale overthrow of physics as we know it, but in that case we can equally allow for free energy from the vacuum of space. In the realm of science fiction anything is possible.
    Tom
  13. Rybold
    2,760
    322
    Southern California
    D'oh !
    Update: Here's an image of the plane. Not transparent. I saw an image on another article and now I'm thinking they must have used the wrong image or a stock image.
    http://www.foxnews.com/world/2011/05/13/solar-plane-takes-1st-international-flight/
    Sure, it's no freight carrier, but after we run out of oil, it will be worth it's weight in gold.
  14. rpatterman
    rpatterman Thinking Progressive
    756
    226
    Boulder, Colorado
    Which house of Congress can oveturn the laws of physics?
    Or will this discussion need to be moved to FHof Politics?
  15. qbee42
    18,058
    3,074
    Northern Michigan
    For classical physics, action must be initiated by the House, but the final vote is made by the Senate. For modern physics, essentially anything involving quantum effects, it is a bit more involved, requiring a super-majority of both houses.
    Tom
  16. MJFrog
    MJFrog Active Member
    780
    266
    NE Oklahoma
    2018 Nissan LEAF
    You forgot to add "and an act of God." :eek:
  17. Corwyn
    2,171
    659
    23
    Maine
    Sure there is (at optimum velocity):
    Energy / unit weight / unit distance = (((CdA)^1/2) / E)g
    where Cd = coefficient of drag (already pretty optimized)
    A = frontal area
    E = efficiency of motor
    g = Gravitational constant
    Since you can express the energy from solar panels in terms of energy density (MJ/kg), they are no different (conceptually) from carrying kerosene.
  18. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    If humans could stand more acceleration, a big rubber band would come in really handy for launching planes. An electric rail launch would be even better.
    And when Arthur C Clarke's dream of a space elevator is realised, the plane could be launched from a great height and glide to its destination. Of course, travelling all the way to the geostationary satellite would be further than the surface distance between departure and arrival points...
  19. austingreen
    austingreen Senior Member
    13,569
    4,107
    Austin, TX, USA
    Not really, kerosene doesn't recharge or get its efficiency decreased by cloud cover. Since a good pilot flies with a safety margin, solar necessarily requires a much bigger reserve. Even if we run out of oil, other processes will allow us to make ethanol or jet-a, so this is really just a feel good demonstration. For anything carrying payload or passengers on a schedule solar is not a viable option. For recreation or spyplanes the tech has merit.
  20. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
