Solar Power to Traction Pack Fan ?
Discussion in 'Generation 1 Prius Discussion' started by TexomaEV, May 24, 2010.
  1. TexomaEV
    TexomaEV Member
    154
    Bonham, Texas
    2001 Prius
    OK, An idea was suggested by a student, regarding the new Prius's having a solar panel built into the roof.
    He wondered if I could install/lay a small solar panel on the rear deck, and have it power the battery cooling/exhaust fan during the day. It looks like it would pull hot air out of the car, while the car is sitting in the sun.
    What voltage is the oem fan powered by?
    Or should I just mount another fan, similar to what you'd find in a PC in the exhaust duct before/after the oem fan?
  2. bwilson4web
    15,524
    I've started using a 5 W, Harbor Freight solar panel designed for tickle charging the 12 V. to power a small, squirrel cage fan in the window to exhaust cabin heat. But I need to add another circuit.
    The variable power supply of the solar cells means it often has voltage but not enough current to handle the motor startup load. What is needed is a storage device, capacitor or battery, to accumulate the power with a load controller with voltage hysteresis:
    • charge a big cap to ~14-15 volts
    • discharge cap into load with solar still connected
    • turn load off at ~9 volts so cap recharges
    I've sketched out a circuit that uses a MOSFET, bipolar transistor, zener and resistors to be a solar, hysteresis controller. However, there are alternate designs. It would be an excellent assignment for students. Give them some design constraints for extra credit. <grins>
  3. oms2burn
    oms2burn New Member
    53
    Midwest
    If I was a student, I would cheat and Google it...This circuit might help.
    You might want to put a big capacitor on there to handle the surge.
    I have not tried this out yet.
    A simple solar panel regulator
  4. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    144
    Fort Worth, TX
    I actually had the same idea, I even posted about it on here several months ago. But I never got around to trying it.
