Solar Roof - Adding a spacesaver spare tyre?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ensoruk, Oct 17, 2014.
  1. ensoruk
    ensoruk Junior Member
    43
    22
    UK
    2019 Prius
    Excel
    Hi
    I'm thinking of buying a new Prius with a Solar roof, but It doesn't come with a spare tyre :-(
    The dealers here aren't very helpful in finding out the parts I need (they have no "bulletin" about this for the Prius)
    Just wondering if anyone has done this and has the part numbers for all the components needed to add a space saver spare tyre ? e.g. the wheel rim, tyre, tie down bolt(?) , jack, wheel brace etc)
    Also wondering if the spacesaver "kit" is the same for both 15" and 17" equipped models?
    I'm in the UK if that makes any difference.
    Phil
  2. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    There's no reason for a solar roof to preclude having a spare (I have both).
    The only Prius cars that lack spares in N. America are the plug-in models.
  3. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    I bought a space saver spare for my PiP from a scrapyard for £20.
    It has a good tyre and is unmarked. It came from a 2002 Avensis.
    The car comes with everything you need to change a wheel, jack, brace etc. under the passenger seat.
    I believe the full specification is:
    PCD 5X100mm, 54.1mm centre hole, and 45mm offset, 135-70-16 tyre.
    Fitted to:
    Avensis 1998-2003
    Carina 1988-1997
    Celica 1994-2007
    Prius 2004-Onwards.
    You need a cover large enough for the standard road wheel so the dirty, wet, punctured tyre may be stored until it is repaired.
    In the UK PiP the spare 'doughnut' fits vertically in the slot just in front of the
    rear bumper where the charging cable is normally stored, the
    cable fits as well. Not too convenient but stops it sliding around and
    you can get at it when the boot (trunk) is stacked.
    But I just chuck it in the boot or if necessary behind the drivers seat. Never been a problem.
  4. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    This must be a UK thing. Here in the USA the Prius with Solar Sunroof do come with a spare tire.
  5. ensoruk
    43
    22
    UK
    2019 Prius
    Excel
    Thanks for the info.
    Sound like the scrapyard might be the best option.... Does anyone know if the spacesaver wheels & tyres are the same on cars with 15" and 17" wheels?
    Phil
  6. Mendel Leisk
    38,705
    There's no difference, as far as I know (have 17" OEM).
    Your Prius is not a Plug-In, correct? I'm thinking your only problem is procuring a spare, no problem with fitting under the subfloor.
    Is this actually the norm in UK: some non plug-in models are missing a temporary spare?? In North America, any non plug-in Prius has the spare.
  7. bisco
    49,434
    just curious whats under the rear deck storage tray where the spare should be?
  8. ensoruk
    43
    22
    UK
    2019 Prius
    Excel
    Good news, thanks , should make sourcing one easier
    yes, not the plug in, so space should be ok
    >Is this actually the norm in UK: some non plug-in models are missing a temporary spare?? In North America, any non plug-in Prius has the spare.[/QUOTE]
    Seems to be the norm in the UK, the brochure says "tyre repair kit only with solar roof"
    Phil
  9. ensoruk
    43
    22
    UK
    2019 Prius
    Excel
    Something like this I believe (skip to 1:00)
    Phil
  10. Mendel Leisk
    38,705
    Sounds like Honda Fit in Canada: manual tran got spare, auto got a pump and slime. Logic was to drop curb weight a bit for fuel economy tests, I think. Spare was available as an option.
    I would check with dealership, if you haven't. Gotta be a very common "upgrade". You'll maybe need more than just the spare, the associated plastic cradle likely varies from the pump version.
  11. bisco
    49,434
    what the heck is that, the battery?
  12. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    That's the battery in a different car--a Plug-in, shown to illustrate how a donut spare can be put in a car without provision for a spare.
    The OP's car is not a plug-in though, so he should be able to stow under the cargo area floor.
  13. bisco
    49,434
    so it's the same space as the u.s. model, just empty?
  14. bisco
    49,434
    wait a second, that's not a v?
  15. bisco
    49,434
    it can't be a plug in, you wouldn't have that space.
  16. bisco
    49,434
    oh, you're talking about the pics of the spacesaver sitting upright. i'm asking about the video.
  17. Mendel Leisk
    38,705
    I think it's the same available volume, but it's got filler plastic in there, molded to hold the pump and slime kit. So he'd need to pull all of that out, get a spare with it's filler plastic. It does look in the video, like the jack and wrench are there.
    The salesman in the video infers the reason for no spare is to reduce weight, get a better fuel economy status. This is sim. to the Honda Fit strategy I mentioned above. Seems very frustrating for owners.
