Solar Roof and top glass gasket deterioration
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by unclebullmoose, Mar 4, 2020.
  1. unclebullmoose
    unclebullmoose Junior Member
    Wadsworth, Oh
    We have a 2013 Prius IV with a solar roof. The glass in front of the moon roof and the moon roof seals had apparently dry rotted sitting in the sun for the last 3 years. Toyota says that the seal on both of the glasses are part of the glass.
    Has anyone had this issue and is there a easier fix. Don't plan on replacing glass that is not broken.
    Plan on going to glass repair shop to see if something can be done there. Would appreciate any good ideas
    from all of you prius folks.
    Thanks.
    Unclebullmoose
  2. pjksr02
    pjksr02 Active Member
    532
    227
    Connecticut
    A glass shop could probably replace the rubber (weatherstripping, sort of). Is the rubber cracked? If not, it might benefit from something like 303 Aerospace Protectant, or another plasticizer product. I've used 303 on all my rubber seals (and hoses, bushings, etc) for years, and it works to keep them flexible and prevents drying..
  3. fuzzy1
    10,356
  4. Mendel Leisk
    41,157
    ^ Yeah, you're not alone. :mad:
  5. unclebullmoose
    Wadsworth, Oh
    Thanks for all the ideas. I thought originally that it was just weather stripping. I plan to go to Advanced Auto Glass to see what they say. If they can't do anything I plan on cutting away the old stripping and trying my own repair.
    Toyota wants $691.00 for the front glass and almost $1100.00 for the moon roof.
  6. Mendel Leisk
    41,157
    And in another 3 years, might be the same story. Unless they've quietly tweaked the weather stripping.
  7. Thankfl
    Thankfl Junior Member
    Maine
    That's it? No solution. Isn't there a part number for just the rubber strip?
    I don't have $1000 to have a new roof put in and that is robbery.stealerships know it too.
  8. fuzzy1
    10,356
    My 'solution', so far, has been to just remove the entire rubber strip and do without.
    Still waiting for something better, but not in an urgent rush to find it.
