Solar Roof charge controller Mod
Discussion in 'Gen 3 Prius Accessories and Modifications' started by heroe1981, Jun 11, 2018.
  1. heroe1981
    heroe1981 Junior Member
    Santa Ana California
    i have a 2012 Prius four with roof solar panel i installed a charge controller that will use the wasted energy that the panel produces when the car is on.the control module for the roof ventilation is located behind the radio it'a a small black box attached to the metal frame with a 10mm bolt the wires are very short so i decided to take apart the actual module solder the 3 wires and drill a hole to get the wires out of the module.i also installed a switch to enable the current flow from the solar panel to the charge controller at any time and i added second switch with a 12v outlet that way i can charge devices with the car off without draining my battery the panel is producing 3.2 amps with the ventilation fan off that's enough energy to normally charge 3 smart phones at the same time.i will post a wiring diagram that i made of my setup
    #1 heroe1981, Jun 11, 2018
    GG707, Mikethe3d, SFO and 11 others like this.
    52,395
    wow, well done!(y)
    namo3 likes this.
  3. heroe1981
    thanks
    namo3 likes this.
  4. RightOnTime
    RightOnTime Senior Member
    791
    1,660
    183
    Kidnapped in OC, CA
    Genius
    iPhone ?
    namo3 likes this.
  5. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Keep up the great hacking. While youre at it, see if you can get put in a 3rd switch to charge the hybrid battery (y)
    namo3, Jisnis and Michael Mann like this.
  6. Michael Mann
    Michael Mann Active Member
    167
    408
    Bay Area, CA
    Great job! Very interested in attacking this one myself.
  7. MPGHokage
    MPGHokage Junior Member
    Utah
    How much did this cost you to do? And how long did it fake to set up?
  8. HarrietMuggle
    HarrietMuggle New Member
    Australia
    i-Tech
    What is the voltage output of the solar panel?
    I searched for this system but only found somewhere somebody says it is 27V, so I am just planning to find a DC-DC converter for it to convert it to 12V.
    There are some 12V small refrigerator that seems can be driven by this panel... have a can of coke in summer is really cool
  9. fuzzy1
    10,603
    Be sure to go by the solar panel's working voltage, not its open circuit voltage. You'll also do better with a charge controller meant for solar systems than with a generic DC-DC converter.
    GG707 likes this.
  10. bisco
    52,395
    is that diet, or classic?
  11. ChapmanF
    18,555
    #11 ChapmanF, Aug 4, 2020
    Mikethe3d and fuzzy1 like this.
