solar roof option
Discussion in 'Gen 3 Prius Main Forum' started by LDB, Sep 4, 2015.
  1. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    I'm going later to look at a Three with the solar roof option. That is the main reason I'm interested in the car. Houston is too hot and my car is parked outside all the time. For those with the solar roof option are you pleased with it? How well does it work? Does pressing the fob button only turn it on or does it cycle on/off? I'd hope it only turns it on as I'd be inclined to try to press it from as far away as possible to get the longest cooling effect before I got to the car. The problem I can see is if you are a few feet too far it won't come on but you can't press again to be sure or you might turn it off so it isn't cooling. Other times you might have just hit the spot and if you do a second insurance press a few feet later you just turned it off. Ideally it can only turn it on so you could press it twice to be sure and not risk turning it back off.
  2. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    The fan powered by the solar roof is actually controlled by a switch on the dash - as long as the switch is on when the vehicle is turned off the fan will run if the sun is strong enough (after a delay of a few minutes). I find it does help keep the interior of the car cooler than it would otherwise be on a bright sunny day. Sunshields for the windshield and rear window help a lot, too.
    The button on the fob is for remote AC, which runs off the hybrid battery if there's enough charge, and if you left the climate control on and in AC mode. The range for the fob is indeed limited, so it's of limited use to turn it on as you walk out to the car. I find it's more beneficial to not turn the AC on until after I've driven a while with the windows/sunroof open to get the hot air out.
  3. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    I had it and loved it. It was one of the main reasons for purchase back in 2010. The solar fan/venting is akin to cracking your windows about an inch but without the security and dust issues.
    Ironically I found it most effective on sunny, cool days during our "winters". We could sit in the car for over an hour with it powered down (key off) while watching our son's soccer matches and pre-warmups.
    Remote A/C (FOB) range is pathetically short and turns off when you open the hatch (groceries).
    #3 fotomoto, Sep 4, 2015
  4. qdllc
    qdllc Senior Member
    1,370
    399
    I DID NOT go with the solar roof (Prius Two) because of how little it would have served me. I got the remote start as an extra. Which, by virtue, lets me remote-start the Prius, and if the AC is on, will engage cooling or heat to work towards the set temperature. It's nice in the winter time.
    The "remote AC" of the Prius Three and higher models only gives you cooling for a few minutes IF you have enough battery power. Maybe that's enough in conjunction with the solar roof powering a fan to lower the temperature in the car, but there's no way 3-4 minutes of AC will "cool" your car enough by itself.
    Of course, in Houston, you don't need to worry about "winter." :rolleyes:
  5. LDB
    LDB Member
    279
    71
    I know 3 minutes or less isn't going to fully cool the car. My hope is the solar fan will keep the inside temp around 110 on a 95 degree day instead of the 150 of a car with no circulation. The remote a/c will mainly just have the a/c fully cooling rather than the brief initial period when things are spooling up to max with others. All combined with light color cloth seats instead of my current black leatherette should make for a much nicer experience.
  6. fuzzy1
    10,167
    I'm in a completely different climate zone, and have never used the fob AC function. I have this feature because the spouse likes sunroofs.
    The solar roof is a mixed blessing. When parked in the sun, it really does keep the car cooler, though not by the 110 vs 150 degree level that you hope for. But when driving in the sun, I can definitely feel more heat radiating down from this black roof than from the silver roof on my earlier 2010. In your climate, you likely have the AC cranked up higher than I use, so may not notice.
  7. LDB
    LDB Member
    279
    71
    I currently keep my a/c set at 60, the lowest setting, and adjust the fan up and down as needed.
  8. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    You can not set 60 with the prius :) I believe the lowest set is 65, after that it says low (whatever that means)
  9. fuzzy1
    10,167
    When using mine, I usually set the temperature to the 75-80 range, and adjust the fan between 1 to 3 bars as needed.
  10. marrat
    marrat Junior Member
    47
    Netherlands
    I've tested it during the hot days here, it makes a noticeable difference. When I entered the car, the air blowing in was relatively cool considering how warm the air outside was. High humidity negates it though, on a day with very high humidity, it didn't make much difference. I expected nothing from it, since I thought "how much difference can air blowing from two vents make?", but I am very impressed.
    I wouldn't go for the solar roof just for that option though, it's not the selling point. The selling point IMO, is how much light enters the car. After driving the car with the cover closed for half an hour for example, opening up the cover makes a huge difference. It makes the car full of light and the perception of the interior space changes.
  11. 3PriusMike
    2,970
    2,321
    Silicon Valley
    The actual number doesn't really mean much. If it is 75 degrees outside and you set it at 75 you will still feel very cool air blowing out.
    How low you want the number to be depends a lot on the humidity, etc.
    Mike
  12. LDB
    LDB Member
    279
    71
    On my better half's Acura it goes down to 65 and then Lo. They claim that is 60 but I don't know for certain. I'll just set mine to Lo and adjust the fan like I've been doing.
  13. qdllc
    qdllc Senior Member
    1,370
    399
    This. The AC puts out based on what's needed to reach the set temperature. More effort at 10 degrees higher than set...less effort when 2 degrees higher than set. Just set it for a temperature you're comfortable with unless you're trying to "max AC" the cabin for a reason.
    Likewise, I'm not knocking the solar and 3-minute AC option. It's a nice perk when you live far enough south for it to shine. I'm far enough north that it wouldn't be that big an asset, and it left me with no way to remote start/heat the car during the cold season. Sadly, a lot of "perks" Toyota includes on high trim level seems to cater to a small segment of the population. It's why I went with a Prius Two rather than pay extra. The TWO items I wanted most was a reverse backup camera (which I installed for about $200 aftermarket) and the better driver's seat. The driver's seat wasn't worth paying $3,000 extra for. If Entune was actually worth it (at the time it had poor to mediocre ratings for the one or two things I would have actually used), I would have at least considered a Prius Three.
