Solar Roof Question- Dust filter?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 925PriusGuy, Jul 2, 2009.
  1. 925PriusGuy
    925PriusGuy Winter Gray & Blizzard Pearl Pri
    148
    Northern California- SF East Bay
    Question on the Solar roof. Is there a filter or does the solar fan use the existing cabin air filter?
    I'm just wondering if you park in a dusty area or someones gardener comes along with a leaf blower and blows up a bunch of dust around the car with the solar fan activated, would dust get sucked inside? :confused:
  2. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Being that it uses existing blower motor (though upgraded from non-solar versions), it also uses the existing cabin-air filter. The clean/change interval is 10k miles/20k miles vs. 15k miles/30k miles for non-solar as a result.
    Batavier and 925PriusGuy like this.
  3. Tideland Prius
    16,615
    Yes it will get sucked in. There is the standard cabin air filter though.
  4. jaywolf
    jaywolf Member
    107
    Vincennes, IN
    Yes if you read the maintenance schedule you have to replace the filter more often on sunroof cars.
  5. Caballo Prieto Azabache
    Caballo Prieto Azabache Junior Member
    Just what I was searching for. Thanks for the info!
  6. phickson
    phickson Tron Pod Occupier
    89
    31
    Maryland
    And change the filter yourself - don't have the dealer do it. They will charge you a bunch of $$. Go to Amazon (or similar website) order the filter for 14 bucks (or so) then watch a YouTube video on how to change it (it's behind your glove box). You'll get satisfaction of saving money and being a handy person all at once!
    prinut likes this.
  7. prinut
    prinut Pri Nut
    102
    23
    SouthFlorida
    Great info!! Thanks!
  8. sushiDot
    sushiDot Junior Member
    36
    Whats the popular filter to use? I just ordered the FRAM CF10285
  9. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    That's the better of the 2 options. The other is cheaper, made of plain paper and lacks any odor control.
  10. sushiDot
    36
    How long does it typically last?
  11. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    On most Toyotas, 15K miles. Using the solar roof ventilation option frequently, maybe 10K miles. Easy enough to pop it out and have a look. When in doubt, replace it. Even minor airflow restriction can noticeably impact A/C and heater function.
