solar roof
Discussion in 'Gen 3 Prius Main Forum' started by franpb, May 25, 2013.
  1. franpb
    franpb New Member
    I do not think th solar roof is working on my new prius 4. Is there a switch I must turn on?
    JMD likes this.
  2. snoctor
    snoctor Member
    126
    27
    Davis, CA
    Yes. On my 2010 the switch is on the dash to the left of the steering wheel.
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    As I recall the switch has a fan like symbol on it. Also the car must be warm for it to activate. You can leave the switch on all the time but the fan won't run unless it's hot in the car and the sun is intense enough to generate enough power. The switch sits "in" slightly when on. The fan also won't run unless the car is "off".
  4. fuzzy1
    10,166
    ... and it has about a 10 minute delay, after turning the car off, before the fan comes on.
  5. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    So, you must depress the button (it has two positions but the depressed position is only a mm or so lower than the "off" position) while in Ready mode.
    Then, 10 minutes after powering the car off, if there's sufficient sun (and the interior of the car isn't cold) the fan should run.
  6. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    The fan will run even if the inside is cold. It just needs sun. Its not on a thermostat.
  7. Tideland Prius
    16,128
    There's a temperature limit. It won't run if the interior is cooler than 20°C.
  8. p00kienrayray
    p00kienrayray Active Member
    720
    135
    Long Beach, CA
    make sure the button is pushed in and not out.
  9. techno-Zen
    techno-Zen Junior Member
    Mesa, Arizona
    I wish I had this version, living in AZ and all.
  10. YoDaddyAlex
    YoDaddyAlex Member
    271
    Are you sure? So you can't leave the button pressed, you have to unpress it, then press it while in ready mode every time?
  11. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    The outside temperature needs to exceed 70 degrees
  12. fuzzy1
    10,166
    It does not need to be pressed every time. I never almost touch mine, and occasionally get surprised to find it running early in the season.
  13. Mark Knight
    Mark Knight Junior Member
    31
    Grand Rapids, MI
    will the fan still come on if windows or moon roof is open?
  14. p00kienrayray
    720
    135
    Long Beach, CA
    No just press it in and leave it on. If u want it off, then press it out.
    Yes. As long as the car is not on, the fans will come on as long as the conditions that are stated in earlier posts are met.
  15. JMD
    3,779
    1,282
    Leaving the solar roof on is good for lowering the in car temperature which keeps the large traction battery cooler.
    Th cabin air filters will get dirtier quicker
  16. p00kienrayray
    720
    135
    Long Beach, CA
    Luckily for us, the cabin filter is cheap and super easy to replace.
    JMD likes this.
  17. YoDaddyAlex
    YoDaddyAlex Member
    271
    I laughed when a local dealership wanted 100 dollars to replace my filter.
    JohnL11935 likes this.
  18. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    I guess I was unclear. The instructions were for initially trying it out. I leave mine pressed in all of the time.
    JMD likes this.
  19. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    My favorite configuration is to park with the sunroof tilted up and the shade open a couple of inches. Having it all the way open will block the cells and let in a lot of the sun.
    Mark Knight and p00kienrayray like this.
  20. David Beale
    5,963
    1,981
    Edmonton Alberta
    I have the little plastic covers over the side windows (curved plastic over the top of the window). They keep -most- of the rain out if it rains and hide the fact I leave the front two side windows down about a cm. When the fan runs I -suspect- I get more air flow because of the windows being open. Certainly the hot air, which resides at the highest point in the car, can exit easier.
    I'd like to see some measurements of the traction battery temperature to prove the idea the solar powered fan keeps it cooler. I suspect it does little to affect the temperature that low in the car.
    Mark Knight likes this.
