Solar Sun Roof Hack?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by imgr82day, Mar 3, 2010.
  1. imgr82day
    imgr82day New Member
    Burbank
    Anybody familiar with anyone getting schematics for the sun roof panel? I was possibly considering some type of hack which would allow you to charge your cell phone with the solar panels using either the 12volt cigarette lighter or perhaps tapping directly into the hot wires from coming from the solar panels themselves. This energy could be used to run small portable electronics, gameboys and or electronics thermos (keeping hot things hot/cold things cold).
    The Sharper Image once sold this item which hooks up to your 12 volt in the car which (depending on setting) would either warm your food item (i.e. Pizza), or cool your item (i.e. cold 2 liter drinks)
    Just a thought? Springtime is almost here, I'm ready to go on a picnic! :)
  2. fmi
    fmi Junior Member
    24
    Phoenix
    It be nice if there was some sort of hack for the solar roof that could trickle charge the 12V battery. That way you could charge a mp3 player or a phone while the car is off and not worry about the battery going dead.
  3. ScottG10
    ScottG10 Member
    132
    Bothell Wa.
    Anybody know how much current is available from the roof?
  4. Tekmann
    Tekmann New Member
    Australia
    I'm suprised they dont do that, and if my assumption is correct, and it only stabilises cabin temps when car is not running, what happens to all that clean power created from roof during [WinteR] months even though less.
    Maybe it could heat up the car during winter tooo...lol
    Cheers
    Tekmann
  5. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    It depends on sun light strength, 0 watt to 59 watts.
    Ken@Japan
  6. UsedToLoveCars
    UsedToLoveCars Active Member
    448
    102
    12 volts @ 59 watts?
    wow... that's enough to run some laptops.
  7. ken1784
    2,940
    1,365
    67
    Yokohama, JAPAN
    The solar panel itself does not have the voltage control function.
    We have to have an MPPT Solar Charge Controller.
    Ken@Japan
  8. ScottG10
    ScottG10 Member
    132
    Bothell Wa.
    I was thinking it would be great to be able to charge a laptop or camera battery.
  9. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    Actually,
    The solar roof does not provide enough power to charge the battery. :(
    I think even if you were to leave it in direct sunlight for 3 days, your battery might go up a bar maybe 2. Not much of a difference. However, the 12v battery would be cool to try out. :)
  10. brad_rules_man
    brad_rules_man Hybrid electric revolutionizer
    716
    76
    Effingham
    I'm pretty sure some peeps have modded it to charge the 12v, which in theory you could turn around and use it to charge up devices using an accessory outlet, or putting in one of your own.
  11. ken1784
    2,940
    1,365
    67
    Yokohama, JAPAN
    Actually, there is a Japanese Prius enthusiast, who developed Japanese CAN-View, installed a 45W solar panel on his Gen2 Prius.
    It charges HV battery. He reported the charge level is up 14% SOC (approx 0.04 liter of equivalent gasoline energy) on a typical sunny day.
    He used to see 30 km/L (70.6 mpg) mileage number on his 7km short commute, then it becomes 36.2 km/L (85.2 mpg) after the solar panel installed.
    A good news is he already replaced the Gen2 Prius with Gen3.
    Of cause, his Gen3 comes with the solar option.
    He is now trying to hack the solar system to charge the HV battery.
    We'll see some news from him anytime soon.
    Ken@Japan
  12. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    59 Watts = 12V * 4.9A
    That is at its peak.
  13. Alexmark
    Alexmark Junior Member
    It is probably weird to post my question here, since the last post was written in 2010, but I hope that somebody will see my message.
    I have the same idea to charge the external battery (let's name it EB) and use it as a portable charger for camera and/or cell phone later. I was thinking about 12V to 5V converter, or just cigarette lighter connector to charge the EB.
    I think that the Solar Panel is constantly producing the current that I can utilize for my idea. I am not expecting to charge my main 12V battery, or Hybrid battery, and 59W is quite enough to charge my EB all day in Florida and use that charge later.
    I have no guts to rip off the car interior in purpose to find the output wire, and can't find any wiring scheme for the Solar Panel in PriusChat or Google.
    Any advises, guys?
