Solar trickle charger install question
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Nov 4, 2010.
  1. ski.dive
    ski.dive Active Member
    959
    241
    Hutchinson Island,FL. Mt. Snow,VT
    OK:
    Leaving the Prius for 3 months
    I just purchased a Solar trickle charger.
    ++ Can I install the clips at the fuse box area under the hood [pos.+ and -negative post]?
    *** The fuse box connection area is alot easier, if it works there.
  2. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You can install it at the jumping terminal. See your user manual.
    JeffD
  3. ski.dive
    959
    241
  4. jdenenberg
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
  5. ski.dive
    959
    241
  6. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    They both do the same thing, so it should be OK. Lots of folks use a solar system to keep the 12v happy.:D H
  7. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    First off, how much power does the Solar unit put out???? I have a 4Runner that EATS batterys for fun, Now that I have the Prius I had to park the 4Runner for extended periods of time. That being said I tried the Solar route, that just turned out to be a LARGE waste of money! I ended up putting a Optima yellowtop in the 4Runner and purchased one of these from my local Toyota dealer. You can also find these units at Amazon.com..
    Amazon.com: ctek battery charger
    Here is a You tube video of the unit...
    Since I have used this unit, I NEVER HAVE TO WORRY that the battery in the truck will be dead. It is a very smart charger, and for the last 14 months the 4Runner starts up EVERY time.
    Since I had trouble on my last 3 week vacation where my Prius battery died twice, I ended up buying a Yellowtop for the Prius as well as a second Ctek unit for the car. Now if I ever have to leave the car parked for an extended time, I just pull a extension cord to the car, plug it in!!!
  8. ski.dive
    959
    241
    Update:
    Well, I hooked up the solar battery charger to the fuse box area battery jumper post [pos.+ & neg.-]
    I will not know if it works until I get back from my 3 MONTH TRIP.
  9. richard schumacher
    7,664
    1,043
    United States
    You should have bought a COROLLA (the most RELIABLE CAR in the WORLD) and then you wouldn't have any worries.
  10. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    I guess it worked for him LOL. Its been years and we havent heard him say his battery died.
  11. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Unless he hasn't gotten back yet. ;)
  12. randerson9248
    randerson9248 Junior Member
    66
    SF Peninsula, CA
    Or,
    He liked traveling so much that he never returned.
  13. Mike500
    Mike500 Senior Member
    2,593
    766
  14. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    Okay and the results are plz
  15. NortTexSalv04Prius
    915
    115
    :focus:
    Has any1 tried the solar trickle charge with optima yellow top
  16. kirbykirb
    kirbykirb New Member
    Tampa, FL
    If only everyone had that option!
