solution for P0420 and P0000 > new rear O2 sensor
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wddanie, Jun 22, 2012.
  1. wddanie
    wddanie Junior Member
    58
    Atlanta
    My 2005 Prius with 125k miles has been showing codes P0420 and P0000 with increasing frequency for about the last 2 years. I had been able to clear them and pass emmissions inspection in the past, but that no longer works since the CEL came back on after about 20 miles and I now fail the test.
    I read up on the codes and thought I might have to replace the cat, but I decided to first try replacing the O2 sensors before and after the cat. I could not figure out how to remove the connector for the forward cat without pulling the inverter so I put that replacement on hold and changed the rear O2 sensor in 45 minutes. I am happy to report no CEL after 150 miles so I think I solved the problem and hopefully will pass inspection this weekend.
    I was too busy to do detailed component troubleshooting and decided to shotgun the problem with O2 sensors. I bought them at Rockauto:
    DENSO
    2349056 (234-9056)
    Oxygen Sensor
    $ 108.79
    $ 0.00
    $ 108.79
    DENSO
    2344623 (234-4623)
    Oxygen Sensor
    $ 57.79
    $ 0.00
    $ 57.79
    I hope this helps others who come across this code in the future.
    Good luck,
    Doug
    SFO likes this.
