[SOLVED for $0] -- 2010 misfire, stumbling, stuttering, coolant loss, head gasket, etc. symptoms
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Atari, Mar 16, 2019.
  1. Atari
    Atari Member
    84
    47
    Sacramento
    I've been on track for Gen4 into Gen3 engine swap or minimally a head gasket replacement in my 2010 Prius V. It's been stuttering and stumbling BAD at nearly every stop sign lately.
    As far as I understand it, this is the same issue/set of symptoms that Toyota is replacing intake manifolds, EGR's and people cleaning their PCV through EGR system (replacing PCV's, cleaning pipe, cleaning EGR cooler, unsticking EGR valve, even installing Oil Catch Cans / OCC's). I've done all that and more (replaced plugs, coils, cleaned injectors, etc.). Hell, my avatar is of the first dump of the contents of my own oil catch can -- which did NOT solve the terrible misfire/stumbling issue.
    So how crazy is it that removing the o-ring from the coolant cap solved all symptoms instantly?
    I mean instantly. No more stumbling. No more coolant loss. What the heck.
    One thing I can add to the mystery is that I did notice that even after 24+ hours of sitting, or sitting overnight in the cold - when I would unscrew there coolant cap there was always considerable or noticeable amount of pressure there "PSSSSSSSSSSSSSSSSSH!" each time I would open it to add a little more coolant.
    I discovered this "fix" on youtube from this guy...
  2. ChapmanF
    18,240
    Why do you think it helped? What do you think the other consequences will be?
    Atari likes this.
  3. Pluggo
    Pluggo Senior Member
    608
    533
    Folsom, Pennsylvania
    I agree that it doesn't make sense. But it's going to be the first thing I will try if the problems begin to hit me.
    Atari likes this.
  4. Atari
    Atari Member
    84
    47
    Sacramento
    So here's where I was.... I was ready to keep adding coolant ("cheap" ZEREX ASIAN red at this point -- because like a 1/2 a pint a day was going somewhere) until the thing totally shook itself silly and broke down. Then I was going to do the 2016 Gen4 engine into Gen3 swap. I figured... I have a short 10 minute commute, I'll get the most I can out of the existing engine before spending $900-1200 or whatever on Gen4. The longer I go, maybe the cheaper that 2016 engine gets.
    So without being a master mechanic, I assume it was getting more pressure than it should have in there from a small leak (let's say cyclinder 1) pumping gas/pressure back into the coolant system. But apparently not enough pressure to throw the relief valve??
    OR maybe the coolant cap relief valve is/was just broken?
    Consequences? I have no idea. You would think that all the coolant will boil and vapor off since the system ins't sealed. But drove for an hour and did not experience that at all. For the first time in a long time -- zero stumbles and not a drop of coolant loss (that I can see).
    So, back to you then...
  5. Atari
    Atari Member
    84
    47
    Sacramento
    Could it be... these mysterious stumbling issues that Toyota has been chasing down. Could some of these failures be caused by faulty coolant cap pressure relief valves on the coolant reservoir caps??? How stupid easy would that be to fix. :(
    Huh... or could it be that Toyota overshot the PSI spec for the cooling system cap?? If a bunch of cars shook themselves to early death as a result, that might be recall worthy if so. Again, not a mechanic. Just speculating. :)
    For what it's worth, my cap looks original and says 108kPa.
    #5 Atari, Mar 16, 2019
  6. mjoo
    mjoo Senior Member
    1,156
    1,328
    Michigan
    Without pressure in the cooling system you're encouraging hot spots in your engine. This could mean detonation = metal chunks flying out from your experiment. I'm glad there's a firewall...
    Pixel XL ?
    scona and Raytheeagle like this.
  7. Atari
    Atari Member
    84
    47
    Sacramento
    Have you ever been in one of these Gen3 Prius's while they were shaking and misfiring? Not sure how it could be much worse.
    mjoo likes this.
  8. scona
    scona Active Member
    225
    207
    Courtenay, BC, Canada
    2013 Prius v wagon
    Sounds like the system is no longer pressurized. So possibly, in theory, the lower pressure in the cooling system precludes the forcing of fluid into the upper cylinder(s). If so then it (the system) should operate at a lower temperature as well. In days of old when a car engine ran too hot unscrewing the radiator cap to the first release point used to do a similar thing. In that case, and in yours I think, it is a workaround not a permanent fix to a problem.
    Atari and mikey_t like this.
  9. Atari
    Atari Member
    84
    47
    Sacramento
    Good point. I'll get one of those OBD bluetooth dongle things for Torque app and measure all the temp points I can with and without the coolant pressure.
  10. AzWxGuy
    AzWxGuy Weather Guy
    1,055
    538
    Tucson, AZ
    2021 Prius
    Atari, I just have to remark on how much your first OCC emesis avatar reminds me of Edvard Munch "The Scream". Perhaps this speaks somehow to the underlying problem. Another symptom of head gasket failure to be wary of in the future.
    Atari likes this.
  11. mjoo
    mjoo Senior Member
    1,156
    1,328
    Michigan
    I personally would use a head gasket stop leak. That way you have a pressurized cooling system.
    Pixel XL ?
  12. ChapmanF
    18,240
    There aren't sensors in the places the hot spots are likely to be.
    One of the consequences of depressurizing the cooling system isn't so much that all the coolant vaporizes and escapes the system, but only that there are local spots within the system where the heat is most intense, and those spots locally boil the coolant to vapor, losing liquid contact with the metal to carry the heat away.
  13. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    And he didn't really "fix" the problem, he just covered it up.
    With no pressure in the cooling loop, the leaky head gasket doesn't present as much of a problem.........for now.
    But the head gasket still is BAD and water likely will still leak into the oil and add to whatever damage there already has been to the bearings. Oil might migrate into the coolant too.
    The coolant also will boil at a lower temperature and the next complaint likely will be: The HOT light did not come on but there is steam spewing out anyway.
  14. Atari
    Atari Member
    84
    47
    Sacramento
    Good catch (pun). I photoshopped the face from the scream in there, because I felt the same.
  15. Atari
    Atari Member
    84
    47
    Sacramento
    The only problem with this is that while I do plan to replace the engine with a 2016 Gen4, I don't want to replace anything else outside (i.e. heater core, 3 way valve, etc.) that might get damaged by "stop leak". I'm having that problem right now on a 2006 prius -- had to flush out the heater core because stop leak was used for head gasket repair.
  16. Atari
    Atari Member
    84
    47
    Sacramento
    So in theory, if your theory were to be occurring, then my coolant level should drop over time? Or are you suggesting "boil to vapor" in one area and distilled or whatever and recaptured in another? As mentioned in first post, my coolant level was dropping 1/2 pint or more a day. It is stable now.
  17. Atari
    Atari Member
    84
    47
    Sacramento
    So then I have to wonder... what was T-SB 0012-10 about?
    (The TSB where Toyota was replacing intake manifolds and EGR pipe gaskets.)
    But where does this problem actually START.
    It's clear that it happens often enough to indicate a design flaw of some sort, but where does it originate?
    I'm not entirely sure I have a head gasket leak, but I've done so much here without fixing the problem I don't know what else it could be.
  18. frodoz737
    frodoz737 Top Wrench
    4,702
    2,499
    33
    The work around is just get in the habit of pressing the accelerator when you press the power button. Learned this here and it still works 2 Prii later.
  19. scona
    scona Active Member
    225
    207
    2013 Prius v wagon
    My guess is you are probably correct with your assumption that the head gasket is leaking. You just may have invented the definitive analytical test for proving that. Why it happens(the leakage) is another story that remains to be told, however. If you are going to replace the engine anyway then what do you have to lose by running it without the O ring?
  20. Borninblue
    Borninblue Active Member
    233
    158
    Cleveland, Ohio
    I guess as the old saying goes “do you feel lucky punk?” Or maybe a thrown rod will not injure someone...
    Atari likes this.
