Some (deep) notes on the Gen 5 transaxles
Discussion in 'Gen 5 Prius Technical Discussion' started by KMO, Aug 8, 2023.
  1. KMO
    KMO Senior Member
    1,518
    395
    Finland
    2023 Prius Prime
    I used to be deep into this stuff when the Prius was new, and I had months to kill while on a Gen 2 waiting list in 2004. It's coming back to me now I've got a Gen 5 on order. (I knew Toyota would crack and produce a Prius I'd be happy to swap a G2 for one day...)
    As Professor Kelly at Weber Auto hasn't done a video for the G5 yet, I've been deep digging into the New Car Features, to see what's going on in the new transaxles.
    Not a lot, is my preliminary answer.
    Rather boringly, the PA10 (1.8 HEV), PB10 (2.0 HEV) and PB12 (2.0 PHEV) transaxles used in the Gen 5 are very similar to the P610 in the Gen 4.
    The transitions from G2 to G3 and from G3 to G4 had some significant transaxle design changes. This seems more like the G1 to G2 transition - a refinement that simply improved the individual components. I can't actually see any structural changes since G4 - the layout seems the same as the P610. But all the bits are bigger and stronger.
    The only fundamental change I see is that the G5 PHEV has dropped the one-way clutch at the engine flywheel. Both HEV and PHEV G4 had the same 53kW MG2, and the engine clutch allowed the PHEV to add extra power from MG1 without spinning the engine backwards, giving a total of 68kW (92PS) in EV mode.
    G5 actually has different specced MG2s - 83kW for the 2.0 HEV and 120kW for the PHEV. That 120kW (163PS) means MG1 doesn't have to help in EV mode any more, so the clutch is gone, and we're back to traditional MG2-only EV mode.
    What's not clear in the docs is what makes the PHEV's MG2 120kW rather than 83kW. The Japanese brochure says it's the same motor (1VM), and it appears to be mechanically the same size in the PB10/PB12 diagrams. Two possible factors are that they've raised the specced voltage from 600V in the HEV to 650V in the PHEV, and that it can end up running faster, due to the PHEV's increased final drive ratio, but those don't seem to be enough on their own.
    Other changes are just to gearing ratios, as far as I can see. The motor rpm limit seems to be staying at 17000rpm same as the G4, and the drive ratios shift a bit - increasing for the HEV, apparently mainly just to accommodate the larger wheels, and decreasing for the PHEV, possibly because there's now much more torque in the PHEV MG2, so it can afford to get closer to the HEV ratio, and raise the max speed closer to 180km/h.
    The detailed numbers for those who care:
    Core planetary gear remains 78:23:30, as in all Prius generations.
    Final drive ratio = 74:20 (3.700) on G5 1.8 HEV, 77:21 (3.667) on G5 2.0 HEV, 78:20 (3.900) on G5 PHEV, compared to 73:21 (3.476) on G4 HEV, 71:19 (3.947) on G4 PHEV.
    Counter gear ratio = 49:53 (0.925) on PB10 and PB12 (2.0 engines), compared to 53:65 (0.815) on P610 and PA10 (1.8 engines).
    MG2 reduction ratio = 53:16 (3.313) on PB10 and PB12 (2.0 engines), compared to 65:17 (3.824) on P610 and PA10 (1.8 engines).
    Resulting MG2:wheel ratio = 10.838 for G4 HEV, 11.535 for G5 1.8 HEV, 11.229 for G5 2.0 HEV; 12.307 for G4 PHEV, 11.944 for G5 PHEV.
    Resulting speed for 17000rpm MG2 = 187km/h for G4 HEV, 185km/h for G5 1.8 HEV, 193km/h for G5 2.0 HEV, 165km/h for G4 PHEV, 182km/h for G5 PHEV. (Limiter is clamped to 180km/h for all G4/G5 HEVs, and set to 162km/h for G4 PHEV and 177km/h for G5 PHEV, which seems consistent).
    Inverter/motor voltage = 650V in G5 PHEV, 600V in the rest of G4/G5.
    MG2 power = 53kW for Gen 4, 70kW for G5 1.8 HEV, 83kW for G5 2.0 HEV, 120kW for G5 PHEV.
    MG2 torque = 163Nm for Gen 4, 185Nm for G5 1.8 HEV, 206Nm for G5 2.0 HEV, 208Nm for G5 PHEV.
    Theoretical MG2 effective torque = 1.8kNm for G4 HEV, 2.0kNm for G4 PHEV, 2.1kNm for G5 1.8 HEV, 2.3kNm for G5 2.0 HEV, 2.5kNm for G5 PHEV.
    #1 KMO, Aug 8, 2023
  2. KMO
    KMO Senior Member
    1,518
    395
    Finland
    2023 Prius Prime
    Okay, one more minor difference. Not mega-exciting, but looking for anything here. There's a change to the oil pump mechanisms in the transaxle, improving its EV capability.
    P610 uses a combination of a sling type lubrication mechanism (from the output) to literally throw oil up to catch tanks, and there is also an engine-driven oil pump. The engine-driven oil pump sends more oil to the motors through a heat exchanger to cool the oil.
    The G4 PHEV might not run the engine for a prolonged period, so it adds an electric oil pump that's presumably only turned on when necessary. That pump increases flow in the transaxle, but as far as I can tell it does not send the oil through the heat exchanger.
    The G5 transaxles all drop the sling lubrication for dry sump lubrication. They have an output-driven oil pump and an engine-driven oil pump, again with the engine pump sending oil through the heat exchanger in the HEV.
    Then instead of an extra electric pump, the G5 PHEV adds 2 control valves allowing the output-driven oil pump instead of the engine-driven pump to send oil through the heat-exchanger-to-motor path. This means we can achieve full cooling and lubrication capability in EV mode, and it can actually choose whether to use the engine-driven pump or output-driven pump or neither for heat exchange at will, giving it a choice of cooling+lubrication levels at any time.
    #2 KMO, Aug 9, 2023
    Louis19 likes this.
  3. Louis19
    Louis19 Active Member
    378
    338
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    @KMO I tip my hat to you ;) for sharing your deep notes with us....just curious if you know the weight gain from the P610 to to the PB 12 since all the bits are bigger and stronger
  4. KMO
    KMO Senior Member
    1,518
    395
    Finland
    2023 Prius Prime
    Interesting question. From the NCF specs:
    P410: 92kg
    P610: 81.3kg (both HEV and PHEV)
    PA10: 85.6kg
    PB10: 93.5kg
    PB12: 93.5kg
    Comparison with other models:
    P710: 95.9kg (Camry/ES300h/RAV4 2.5 HEVs)
    P810: 111.8kg (RAV4/NX450h+ 2.5 PHEVs)
    #4 KMO, Aug 9, 2023
    Louis19 likes this.
  5. Louis19
    378
    338
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Thanks , by any chance do you have the weight difference of the engines for Prime 22 and Prime 23
    (phev models 1.8 litre vs 2.0 litres )
    #5 Louis19, Aug 9, 2023
  6. KMO
    KMO Senior Member
    1,518
    395
    Finland
    2023 Prius Prime
    Best I can do is this pair of hard-to-compare numbers:
    2ZR-FXE: 90kg (with water and oil fully filled), from Prius G3 specs - not shown in G4 or G5 specs
    M20A-FXS: 113kg (without coolant and oil)
    Louis19 likes this.
