Some idiot worked on car/Cracked plastic/Fix?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cyberpriusII, May 18, 2015.
  1. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,151
    1,701
    Mars Hotel
    During the weekend, some bubblehead :whistle: was working on my Prius and cracked the plastic relay case cover.
    I bought some Permatex RTV high temp black gasket stuff and was going to run a bead along the crack, which I think should be fine, but as I just about got ready to do it, thought, hmmm, there might be some obtuse reason why I should not?
    This is just a short fissure on the top, solid all around it and I don't think the "integrity" of the cover is impaired, other than the small crack.
    Anyone?
  2. JC91006
    16,673
    8,518
    :rolleyes:. Put the cover back with the crack, you'll be fine and nobody will see it.
  3. Stevewoods
    Stevewoods Senior Member
    655
    1,070
    Seattle, WA
    Don't know why you should not do it.
    But, do know why you should probably do something. Electricity and water do not mix. And while I doubt there is a great chance of water getting in, why take the chance that it would. Esp. for 20 cents worth of make-a-gasket.
    I think I have read a few instances of water getting into the sparkplug/coil set-up (might not have been on Prius) and creating some hassles. And, no, this is not your problem, but again, it is water and electrics....
    #3 Stevewoods, May 18, 2015
  4. ChapmanF
    17,347
    Which cover did said bubblehead happen to crack? 82662A or 82662B?
    Ok ... I guess they are a bit more than a tube of Permatex black ....
    Or you could just schmutz a soldering iron tip down along the crack and call it good....
    -Chap
  5. cyberpriusII
    1,151
    1,701
    Mars Hotel
    Tube of Permatex Black $3.44. New Toyota Part: Priceless.
    Yes, I was worried about electronics.
    I just did it. It looks pretty good. I did get three mosquito bites while doing it, but held steady anyway. Now, I just know that someone will pop up and tell why I should not have done it.
    Don't have a soldering iron. Never learned that trade.
  6. ChapmanF
    17,347
    If you haven't learned the 'official' use of a soldering iron, you can still use it to melt random things and make them blobby, and that can be fun.
    $3.44 is cheaper than $36.67, but for me to decide whether that was priceless or not, I'd have to know more about Iowa mosquitoes.
    -Chap
  7. Priusyipee
    Priusyipee Active Member
    354
    269
    Upstate New York
    Did the "bubblehead" offer to replace the cover?
  8. ChapmanF
    17,347
    Hmm, it seemed the bubblehead was let off easy for some obscure reason. :whistle:
    -Chap
  9. Priusyipee
    354
    269
    Upstate New York
    :eek:
  10. cyberpriusII
    1,151
    1,701
    Mars Hotel
    I am a generous and friendly soul. One of the happy Prius owners. So, said bubblehead had no liability -- other than $3.44. o_O
  11. ETC(SS)
    6,958
  12. cyberpriusII
    1,151
    1,701
    Mars Hotel
    Hey, that is exactly who did the work! Lots of submarine crews here in Iowa.
  13. ETC(SS)
    6,958
    Yeah....but most of the ones in IA are nukes.
    Great operators....but they're rather process oriented.
    Not what you would call outside the box thinkers.
    Sincere apologies for my earlier objection. :D
  14. Mendel Leisk
    40,584
    I once noticed a whistling noise from a car, parked after a long drive on hot day. Next time I was in for a service (I wasn't DIY'ing at the time) I asked the service writer if that was normal. I was pretty sure, just the gas cap venting due to some pressure limit, but just thought I'd ask.
    Anyway, a few days later, started noticing a gas smell around the car. Yup: they'd drilled a hole through the cap, to remedy the whistle. I bought a new cap, maybe $30.
  15. JC91006
    16,673
    8,518
    :LOL::LOL::oops:
