Some interesting Recall happenings. Need advice
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ryan Bennett, Jan 4, 2013.
  1. Ryan Bennett
    Ryan Bennett Junior Member
    62
    17
    Hey everyone.
    Took my '09 Prius in for the steering column and water pump recall today.
    They inspected the steering column and replaced a bolt. The steering wheel sits slightly to the left now for me to drive in a straight line. This is very frustrating for me, because it (and the alignment) was perfect before I took it in. Why would this happen if they just replaced the bolt? The service department claims it should be fine since the bolt was only replaced, but they're going to take a look at it Monday. Is there anything I should know about to tell them?
    Also, just a general FYI, the water pumps for the 04-09 Prius's are on backorder with Toyota now. Apparantly, they've again changed what kind of waterpump gets installed for the recall, and there currently aren't any available (according to Toyota customer service). If you want to take your car in for the replacement, the dealer can't perform the service right now.
    I had the transmission fluid changed today, so at least that went as planned....
    Thanks in advance for any help/advice!
  2. Ryan Bennett
    62
    17
    I read the procedure, and my guess is that they replaced the bolt as instructed, but didn't adjust the steering alignment back to "0" like they were supposed to. I brought this up, and the service manager said that the steering wheel adjustment shouldn't have been necessary. Obviously it was. I will print that part of the instructions out and take it with me Monday. Thanks for re-posting
  3. Ryan Bennett
    62
    17
    Cwerdna,
    Big thank you for posting the service bulletin instructions. That saved my nice person today. I went to the dealer again this morning about the steering wheel being out of alignment. Again, they said there is no way the steering wheel should have moved since they just adjusted the bolt. I asked if he sat behind the wheel and actually checked it out. He said no. Well, then I pulled out the service bulletin and showed him where it plainly states to check steering wheel alignment after replacing the steering shaft bolt.
    He then disappeared for an hour. He returned and said "OK, the car is ready". Said the alignment was perfect and a bunch of vague talk about the steering wheel alignment.
    Long story short, the steering wheel was perfect when I got the car back. Somebody fixed it, then claimed they didn't to cover their nice person. I don't really care, because it was fixed, but jesus it took two trips and me calling them out on it to finally get it fixed
    Needless to say, I won't be going back there for the water-pump recall.
    Thanks again so much again.
    tomcornell, F8L, dchow007 and 2 others like this.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    No problem. I'm very glad that NHTSA makes those documents accessible, although finding them isn't the most obvious. Long ago, I remember seeing people posting them and I wondered how they found the URLs.
    F8L, dchow007, SyCo and 1 other person like this.
  5. Metrolens
    Metrolens Member
    190
    35
    I had my Gen II 2005 in for the steering recall today.
    All they did was change the bolt. But my steering now seems very slightly off. The car pulls slightly to the left; in order to go straight, the wheel needs to be turned to the right by probably 1-2 degrees.
    The steering wheel was *perfectly* aligned before I left it with them this morning. I specifically told the techs to make sure the steering wheel was perfectly aligned. Even left a letter on the dash. And still this happens.
    Any thoughts?
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Guess I'm lucky. Had mine done last week. Mine only needed a bolt also. And my wheel was straight when i got it back. And tracks fine.
    They did fill the Inverter reservoir right up to the top though. I don't think you can really win these days with the modern car dealer.
    Ryan Bennett likes this.
  7. Metrolens
    Metrolens Member
    190
    35
    Should I insist on having the steering wheel perfectly centered? Isn't that a reasonable request?
  8. UK-Prius
    UK-Prius Junior Member
    UK SOUTH WEST
    Is this cars from the US only?
  9. edthefox5
    10,096
    4,804
    Clearwater, Florida
    Who knows. Most posters are to lazy to fill in their profile.
  10. Metrolens
    Metrolens Member
    190
    35
    Not sure. I'm in the USA.
  11. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Even just changing the bolt can put the steering wheels off center. Unless the steering wheel is somehow locked into a fixed position then once the bolt is removed the steering wheel and upper shaft can rotate very freely. Even just the torque of removing/replacing the bolt could move it.
    The actual wheel alignment however cannot be affected by this procedure. So I'd suggest that the "car pulling to the left" part is either imagined (due to the difference in steering wheel position) or else was already like that before.
    richard schumacher likes this.
  12. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    No the recalls are for UK vehicles also. Check with your dealer the work is free. Two recalls one for steering and one for inverter coolant pump.
    John (Britprius)
  13. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    Yes, that is a reasonable request. I just had mine done, steering wheel is centered as before the recall work.
    DBCassidy
  14. AzWxGuy
    AzWxGuy Weather Guy
    979
    495
    Tucson, AZ
    2021 Prius
    I had my recall work done this morning with no issues noted afterward. They even washed my car when they were done. I waited for just about 3 hours. Considering the animosity generally felt by the PC group toward "stealerships", I would like to formally put in a good word for the dealership I do business with. There is probably a thread or sticky for this somewhere, but let it be known that Desert Toyota in Tucson AZ is a straight-up trustworthy business. Sure, they will charge just as much $$$ for repairs as any other licensed dealership. It is in the nature of these vehicles to be premium priced when it comes to repair or replacement. Any other manufacturer, foreign or domestic, is probably about the same. I wasn't offered any bogus services and never have been. I continue to be a happy Toyota owner.
    Patrick Wong likes this.
  15. Patrick Wong
    18,200
    6,471
    I'm glad to hear you are pleased with that dealership's service department. I have had similar experiences with Precision Toyota.
  16. Ryan Bennett
    62
    17
    This is exactly what happened to me. Others have said this, but they didn't recalibrate the steering wheel to "0". They are supposed to do this, even if they swear up and down that the steering position can't change by replacing the bolt. If you look in the Toyota service bulletin, it plainly states that they are supposed to re-calibrate the steering wheel center position after they replace the bolt.
    In my case, the service manager told me repeatedly that there was simply no way it could be off from replacing the bolt. I pulled out a copy of the service bulletin and showed it to him, where it says you're supposed to check and re-calibrate steering wheel position. He said something like, "oh", and disappeared. An hour later, I got the car back, and they claimed they didn't do anything. That was bullshit. My steering wheel was "magically" back to perfect alignment.
    My guess is that the technician at the dealer covered up his mistake. He fixed it, and didn't tell the service manager. I literally drove to the dealer with f'd up alignment (after they replaced the bolt), and then when I drove it home it was magically corrected. I'll never go back there again. I H A T E taking my car to a dealer, yet you have to when recall work is to be performed. Every time I go to one, they f something up. A good independent mechanic is the way to go in general.
    OK, I'm done venting now. :)
    edthefox5 likes this.
  17. edthefox5
    10,096
    4,804
    Clearwater, Florida
    I know...they make you feel...dirty.:ROFLMAO:
  18. Ryan Bennett
    62
    17
    Absolutely, without a doubt
  19. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Hi Ryan. Roughly how much was you wheel out of alignment? Given that they apparently took no notice of alignment during the procedure was it like 15 degrees or something really noticeable, or was it only small?
