Some Jerk.....
Discussion in 'Gen 2 Prius Main Forum' started by triumph1, Jun 26, 2010.
  1. triumph1
    triumph1 Member
    275
    Stole my driver side mirror- the motor still works, looks like all that's missing is the mirror itself. Any ideas where I can get a used one? I find it odd someone would steal this thing, unless of course this mirror fits many other Toyotas. Just doesn't seem like the average Prius owner would steal off another Prius.........
  2. vertex
    vertex Active Member
    670
    143
    new york
    2018 Prius Prime
  3. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    You might also check with these folks.
    They are a 2004-2009 Prius salvage yard and rebuilder in Indiana. :cheer2:
    Good rep here for service, prices, and shipping. :rockon:
  4. triumph1
    triumph1 Member
    275
    I found a place in Illinois that will ship it for $20. I still don't get stealing mirror glass from a Prius, unless of course it will fit some other car that some "illegal" is probably trying to rebuild. I take it those wires dangling are for models that have heated glass? As far as I know mine didn't.......It sure doesn't now! Whats the best thing to attach it back to the backing plate with??
  5. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    I just replaced my daughter's mirror on a Corolla. It should be a snap in replacement and not an adhesive attach. The backing plate should come already attached to the new mirror. You probably need to pull the old backing plate once you get the new mirror if it is the same on a Prius.
  6. triumph1
    triumph1 Member
    275
    It would be nice if it had the backing plate, I'm not expecting so for $20. It didn't really say whether it came with it or not.
  7. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    You have heated side mirrors. I think all Gen II Prius have heated side mirrors, except for the stripped out base model that Toyota came out with in 2008 and 2009 where Toyota was able to reduce the base price by removing the heated mirrors, wheel trim rings, front seat back pockets, tonneau/luggage/cargo cover, and cruise control.
  8. sktn77a
    sktn77a Member
    294
    NC
    You should have two thin wires coming out of the mirror body with flat connectors that push on to the heated mirror glass connections on the back of the glass. The heating element ist permanently stuck on to the back of the glass. If it's OEM, it should have this. If its aftermarket, it may not. Make sure those two connectors coming out of the mirror body don't touch or you'll have a fuse to replace also.
  9. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    I sure hope you are talking about a thief, and not an undocumented immigrant.
  10. BassMasterCHS
    BassMasterCHS New Member
    Swamps
    local junk yard might have some...its where i got mine
