Some Observations On MPG
Discussion in 'Gen 3 Prius Fuel Economy' started by djlen, Dec 6, 2011.
  1. djlen
    djlen Junior Member
    68
    Somerdale, NJ
    I am totally new at this business of pulse and glide and some of the other terms used here. I'm only on my second tank of gas in my 2011 Prius.
    I am finding that using my cruise control even on surface streets for short runs seems to get me better mileage than using the glide technique. Seems like Toyota's way with computers, in this case the cruise control computer, would keep the car at a more steady pace than my untrained foot. So far it has!
    I have many fairly long sections of road on my 7 mi. commute and find myself going with the cruise control often.
    Has anyone used this in this way? Can I damage it by using it so frequently?
    Or should I be putting more effort into training my foot to do a more consistent job of gliding. Others have mentioned the stress involved in concentrating one's foot and the gauges/graphs etc. I feel a bit of stress when trying for the best mileage I can get.
    Thoughts?
  2. Mendel Leisk
    38,735
    I'm also finding 3rd Gen Prius CC delivers very good efficiency, at steady speeds. Where you can still beat it easily is in stop/start conditions, where you can opt to coast to your next slow down. Especially if there is no one impatient behind you, you can be strategic with your speed, just taking adavantage of momentum, coasting.
    49,505
    wow, cc on surface streets. that would never have occured to me. what speeds are you talking?
  4. Tideland Prius
    16,158
    CC is just a computer program so no damage done for excessive use imo. I've only use DRCC on surface streets, rarely the "constant-speed" cruise control (i.e. the regular mode).
    It really depends on your commute (terrain, traffic, no. of stops etc). P&G really shines in rolling terrain (and it doesn't have to be an obvious up and down hill like the Pacific NW). Gliding on slight descents helps vs. EV-ing in CC (I'm talking about those stretches where it looks flat but it's very slight hill, enough to maintain speed in glide)
  5. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Strange. Most hyper-milers would say that the cruise control is not the best way to maximize MPG. But, if it works for you go with it!
  6. djlen
    djlen Junior Member
    68
    Somerdale, NJ
    Glad to hear these responses. I'm talking about speeds in the 40 to 50mph range generally, keeping a close watch on the lights in order to disable CC in order to coast to the light. I'm a long way from "hyper-miling" believe me. I'm convinced that that is an art that needs to be perfected over time. I will continue to try to get used to the light touch on the accelerator and over time hopefully it will become less stressful and easier to relax.
    Tideland, the ascents are where I feel like the computer in the CC helps me the most. I, as a novice still have no touch on the pedal whereas the CC computer (in my view) seems to know just how much acceleration I need and when to let off at the crest. Keep in mind that this is Jersey and these are more rises than hills.....lol.
  7. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    If the first tank reflects dealership driven miles, then almost anything done during the second tank will appear to be an improvement.
    Selecting the ECO mode gives a more manageable throttle for P&G but if you're driving at a constant 45-50mph there is a better method.
  8. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    The 3rd Gen is a little more finicky when it comes to pulse and glide which is why some prefer the GenII. If you don't have the technique mastered then it can actually hurt your MPG so my advice is to not bother trying to pulse and glide until you have a lot more miles under your belt.
    At higher speeds you can try out Super Highway Mode and other techniques but like I said, wait until you have accumulated more driving time so you can learn how the car works. :)
  9. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    I use CC a lot, but only on freeways. I try to pulse and glide whenever I can on surface streets, and on freeways when traffic precludes using CC. I have even seen the car in glide mode and CC at the same time, although it is rare and doesn't last long. Go with what is comfortable for you, and your mileage will probably improve as both the car and you get "broken in." Warmer weather will also help your mpg.
  10. walter Lee
    1,126
    376
    Maryland
    7 mile commute is a fairly short commute so your Prius' fuel efficiency will drop signficantly in the winter time because of warmup cost. Cruise control(cc) should work better than a normal (extended) Pulse and Glide (P&G) because its more likely to keep your engine running longer for the first few minutes and thus more quickly warming up your Prius to its most fuel efficient operating temperature than an normal P&G cycle. It is only when your engine warms up (to about 140F and then to 180F ) that it will run efficiently and benefit from an extended P&G cycle. When starting from a cold start on a dry but cold (<40) day, the Prius needs to be running for about 15-30 minutes before its FE can fully benefit from an extended P&G cycle.
    Unfortunately, with your 7 mile commute, this means that the benefits of the P&G cycle can only been achieved in the latter half of your commute.
    Because your commute is short you must focus on warming up your gasoline engine (aka internal combustion engine or ICE) for the first 4 minutes of driving. This means avoiding using electrical power ( left side of the ECO bar on the HSI) and use the ICE instead (right side of the ECO bar on the HSI). When not using an engine block heater or some external heating system, hypermilers use a thing call mini warmup P&G cycles. This means from a cold start pulsing the the ICE to 10 mph using the ICE only for the first minute (by pressing the accelerator over the 50% (half way) marker on the ECO bar on the HSI display then letting go the accelerator so that the HSI display is on the very far left of the ECO bar but not in the recharge bar section -so that the Prius glides at 10 mph for a short time just on momentum using very little electric power). When the Prius speed drops to about 5 to 7 mph accelerate further, incrementally increase the top speed of the next pulse to about 15 to 20 mph, repeating this process again but allowing your glide to drop down only to 10 mph to 15 mph before pulsing again. On the next pulse raise your top speed incrementally to about 20 to 25 mph, repeating this process again but not allowing your glide speed to drop lower than the previous pulse top speed. Do this repeatedly until you get to your desired speed. Min/warmup P&G can be difficult to do.
    If you are going on a superhighway setting CC is the easiest way to limit your speed to under 65 mph and get the best fuel efficiency. On the superhighway the prius CC can get about 64 mpg when fully warmed up and driving constantly for hours between 50 mph to 55 mph.
    If you are going on suburban-urban roads then timing your Prius with the traffic lights so it doesnt need to stop at the intersection is your best tactic. In hypermiling lingo = driving without brakes aka DWL. The Prius can achieve an instantaneous MPG between 60 to 80 mpg using P&G at speeds from 15 mph to 30 mph when combined with DWL.
    On fairly long sections of suburban roads when traffic permits it, the Prius FE is best when driving from 25 mph to 35 mph. With a fully warmed up ICE, P&G between 25mph to 35mph can achieve an instantaneous mpg of about 60 mpg to 70 mpg.
    In stop-n-go urban traffic that last longer than 10 minutes, its best to avoid using Electric power (to avoid depleting the HV battery power) and do min-P&Gs to inch along in traffic. MPG can drop as low as 15 mpg if you deplete your HV battery during a traffic jam. On short trips less than 3 miles/3 minutes the Prius gets between 15 mpg to 20 mpg.
    hope this helps
    Walter Lee
    'HyperDrive 1" on cleanmpg.com
    2010 Toyota Prius III, Blue Ribbon/Dark Grey. oem floormats
    Yokohama Avid S33D
    ScangaugeII
    grill blocking
    odeometer 17700 miles, overall mpg = 60.9 mpg
  11. Tideland Prius
    16,158
    At 40-50mph, it'll be tough to P&G since the limit for coasting is 43mph; above that, the engine will spin to counter the electric motor.
    I use the HSI on the 3rd Gen. If you're coasting, you'll be regen-ing slightly and there will be a small bar towards the CHG portion. Lightly press the accelerator til the bar disappears and you have an "empty" HSI scale. That's fairly close to gliding.
    For speeds above 43mph, I would just keep the speed with the throttle pedal within the Hybrid ECO area (the darker green area or the 1st half of the ECO area). I've found at a constant 43mph within that zone to maintain the speed with a warm engine, I can get close to 52 or 59mpg. (I can't tell since my bars are in 0.5L/100km intervals so 4.0L/100km is 59mpg and 4.5L/100km is 52mpg).
