Some Odd Info About the Prius
Discussion in 'Gen 2 Prius Main Forum' started by javawizard, Dec 10, 2006.
  1. javawizard
    javawizard New Member
    I've posted some odd information about the Prius at www.odd-info.com/prius.htm
    Enjoy!
    - Jeff
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    That's nice that you did the write up, but some of your "facts" need a little back checking.
    The battery warranty is for 100k miles in most places, 150k in California Emissions states.
    The latin for Prius means 'before' or "to go before", first is a close loose translation.
    Also, an explaination of why the battery won't die as early as the one in your laptop might be a bit more convincing than just saying it's warrantied that long. Further, it's expected to last the life of the car due to the way the system is designed.
  3. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(efusco @ Dec 10 2006, 07:04 PM) [snapback]360221[/snapback]</div>
    My daughter's Latin teacher translates it as "Leader."
  4. john1701a
    john1701a Prius Guru
    12,797
    5,279
    57
  5. mcsj
    mcsj Member
    125
    Earth
    <div class='quotetop'>QUOTE(javawizard @ Dec 10 2006, 08:56 PM) [snapback]360219[/snapback]</div>
    how about some incorrect info?
    === Quote from that web site ===
    The latest models require no key. Simply click a button on the fob, and you're ready to go.
    === End quote ===
  6. MegansPrius
    MegansPrius GoogleMeister, AKA bongokitty
    2,437
    27
    Chicago, IL
    <div class='quotetop'>QUOTE(john1701a @ Dec 10 2006, 11:55 PM) [snapback]360239[/snapback]</div>
    Thanks John, for the troll alert. The comments in the other thread dissect this nicely.
  7. Alnilam
    Alnilam The One in the Middle
    760
    Carlsbad, CA
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Dec 10 2006, 07:51 PM) [snapback]360237[/snapback]</div>
    "Nihil est in intellectu quod prius non fuerit in sensu."
    Thomas Aquinas, I think.....
    "Nothing is in the mind which was not AT FIRST in the senses."
    "Prius" translates more or less as "previously." You can see the connection with "primus": "first."
    "Dux" means leader. (We get Duke from that.)
    The teacher may have confused it with "prior" which is one who goes first, as in the Prior of a monastery.
