Some Prius II tricks
Discussion in 'Gen 2 Prius Technical Discussion' started by spidgorny, Sep 20, 2010.
  1. spidgorny
    spidgorny New Member
    Frankfurt am Main
    Source: SPidgorny: Three Prius Tricks
    I'm am an owner of European Prius II (2006) and want to share some tips which I find useful, but which took me some time to grasp.
    1. You can go as fast as 182 km/h on Prius if you step on the accelerator (driving at 180) and then the road starts going downhill. It takes the system several seconds to adjust to reduced necessary torque and until then it keeps accelerating as if you're going up-hill leading to 182 (I did this several times already).
      You can get 181 km/h on the plain road by stepping on the accelerator, but that's not as interesting.
    2. Don't use "B" mode to regenerate more energy (I was doing it on every traffic light for half a year because of many contradicting posts in the forums). Read this and apply brakes gently to regenerate more. Use "B" mode only when going down-hill (that's the rare case when you should follow the manual and you will do it right).
    3. If you don't like Pulse&Glide technique then at least use Glide mode to reduce the breaking force when approaching a distant red light.
    4. Navigation without GPS applies to Prius II as well! I noticed it in the underground parking and the system information screen has some kind of bearing information (displayed in degrees) which, combined with distance traveled, can replace GPS for some short distances.
    5. How to get to the system information screen in Prius II - get to the display screen and follow the instructions here (it's not on the Navigation Voice screen, at least not in Prius II).
    davecook89t, geekaren and bisco like this.
  2. jpgoody123
    jpgoody123 New Member
    maryland
  3. Timur
    Timur Junior Member
    Queens
    You can leave car running in hot or cold day in the parking lot. Use metal key to lock the running Prius.
    50,634
    there is a little drawer under the center console most people don't know about. it is filled with gold
  5. Skibob
    Skibob Senior Member
    2,912
    1,501
    Northern California
    Only people that don’t read the owners manual don’t know this. :whistle:
  6. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    And a leprechaun!
  7. Ernest Erickson
    Ernest Erickson New Member
    16
    Arizona
    Technology
    I opened that door under the center console, and found a SPARE TRACTION BATTERY!
    ALCRO, bisco and Skibob like this.
  8. scargi01
    scargi01 Active Member
    784
    57
    Missouri
    Yes, but you will need that gold to pay for the eventual repairs/parts for the Prius.
  9. Hamptgx
    Hamptgx Member
    66
    27
    Northern Illinois
    Aawww damn...mine was full of coal (and a used condom......eewwhh!)
