Some Questions
Discussion in 'Newbie Forum' started by bkk1057, Nov 11, 2011.
  1. bkk1057
    bkk1057 New Member
    Pacific NW
    I have a new 2011 Prius III and have some questions:
    1. The car rocks back and forth when I turn the engine off. I usually switch to Park and then press the On/off button. Is that normal or am I doing something wrong? Do I need to engage the manual brake all the time?
    2. When I back my car up it kind of pulsates; it moves in a kind of jerky fashion. This doesn't happen all the time. It is almost as if it is a combo of involuntary muscular action from my feet and the supersensitive brakes. Incidentally, it happens when my wife reverse also. Is it us or is it the car?
    3. How much mileage should I expect if I drive the car normally and not worry about the right technique in squeezing the last bit of mileage from the last ounce of gas? I have been driving in Eco mode.
    Thanks..
  2. macmaster05
    macmaster05 Senor Member
    4,050
    729
    1. Yes, most people always set the e-parking brake. Doing so will eliminate the rock.
    2. Don't know.
    3. At the least, 45 mpg. I have a Gen II, drive it pretty hard, but still average 52 mpg. Bay Area terrain and weather.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Depends on MANY factors such as trip length (short trips esp. in the city are killer), speeds, weather conditions, the driver, tire pressure, etc. See Most fuel-efficient cars for what CR got.
    Your mileage will fall as it gets colder and rise again in the spring, as it does on all cars.
  4. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    ^^^ as man says it depends.
    Unless you drive like a complete yahoo, or have a bunch cold starts with really short <5min drives with new Gen III you'd do on par or a couple miles over EPA rating of 50MPG, 52-53 w/o effort. A little bit better after break in.
    I am not a hypermiler, but I get ~58-62 in ECO. Key is avoiding using full throttle acceleration (keeping it in ECO band) and maximizing regen braking. Of cause Michelin Energy Savers help, but EP20 aren't bad too.
  5. fulltank
    fulltank New Member
    230
    38
    Arkansas
    I have an '11 Prius IV and DO have to put forth effort to get 50 MPG. If I find myself driving carelessly it will drop to 46 MPG. I've yet to drive a tank of gas that averaged over 50 MPG and I'm on my 6th fill up.
  6. JimboPalmer
    12,470
    6,868
    Greenwood MS USA
    If, like me growing up, you live in a rainy part of Washington or Oregon (say, over 80 inches a year) You will spend a lot of time throwing up road spray with your tires, this will reduce your MPG quite a bit. So will running headlights all day. (which I recommend, safety beats gas mileage) Recognize this as a penalty to your lifestyle.
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    1. This comes from play in the parking pawl. It is not a problem. The normal cautions are appropriate about using the parking brake in adverse conditions, such as steep hills.
    2. The Gen III Prius has a reported problem with touchy or grabby brakes in reverse. A search of this site will reveal a lot of discussion, but no solution.
    3. Typically 45 to 55 mpg, but it varies immensely depending on trip length, speed, and conditions.
    Tom
  8. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    The Prius doesn't have a conventional transmission with gears so it uses a parking pawl to lock things up. Hard rocking on it is not recommended and the parking brake should be used.
    Reasons for pulsing that I'm familiar with are: warped brake rotors, an out of balance wheel, or a bad shock. None of these would make sense on a new 2011 or only in a reverse direction. I'd have a dealer check it out.
    Having owned a 2010 for a year now, I've seen anywhere from 38-58mpg which depends on many variables.
  9. bkk1057
    bkk1057 New Member
    Pacific NW
    Thanks for all the replies. I will have the dealer check out the reverse jerkiness. Which reminds me; the dealer send me e-mail telling me that it is time for my 5000-mile service. This is 2 months after I took delivery of the car. I am nowhere near 5000 miles. Should I just take the car in or wait for 5000 miles?
    This is wonderfully responsive forum. Thanks again.
  10. richard schumacher
    7,663
    1,039
    United States
    Follow Toyota's schedule, not the dealers:
    Toyota Parts and Service
    Don't try to decide whether you're on an incline or not. Just set the parking brake every time. The annoying rocking will go away, and it's safer to have both the parking pawl and the brake holding the car.
  11. PearlJammer
    PearlJammer Member
    112
    23
    Georgia
    2018 Prius
    Same experience here.
  12. Gurple42
    Gurple42 New Member
    354
    Santa Monica, Ca.
    Set the emergency brake before you take your foot off the brake when shutting down the car, solves the rocking, just push the power button, it automatically puts the car in park, no need to push two buttons. Relax, from what you said the car seems ok, also if you drive it without trying for good mileage you should expect mid 40's in mileage.:)
  13. JimboPalmer
    12,470
    6,868
    Greenwood MS USA
    The engine is going somewhere between 0 and 5200 RPM, and Motor/Generaator1 is going somewhere between -10,000 and 10,000 RPM once you turn off the car they wind down to 0 RPM. And since you have turned off all the fancy computers that normally balance all this, you can feel a gentle rocking against the parking pawl as it all slows to a stop.
    If I ever parked on an incline, I would use the parking brake.
    BTW, you can just hit Power and the car goes into Park as well.
    Here is your maintenance guide, the 5000 mile/6 month service is on page 39
    http://www.toyota.com/t3Portal/document/omms/T-MMS-11Prius/pdf/MY11%20Toyota%20Prius%20WMG.pdf
    (I drive my 2009 Gen 2 about 30,000 miles a year, so yes, my 5000 mile/6 month service happens every two months)
  14. richard schumacher
    7,663
    1,039
    United States
  15. mrnoyb
    mrnoyb Junior Member
    52
    NA
    1. I believe this may be the transaxle searching for the parking prawl.
    2. Is it possible you're feeling the shudder resulting from the gas engine engaging?
    3. I drive in normal mode and see 43 mpg on short trips and 53 mpg on longer commutes.
