Some Scangauge X-gauges are not working
Discussion in 'Gen 4 Prius Main Forum' started by roadwarrior28, Feb 14, 2021.
  1. roadwarrior28
    roadwarrior28 Member
    68
    69
    Portland, OR
    Three Touring
    I purchased a Scangauge II with software version 4.53 primarily to monitor temperatures as I do a lot of high load driving. I was able to program in most of the X-gauges specific to the GenIV Prius that were listed on the Scangauge website. The following gauges I couldn't get to work, they don't display any data:
    Hybrid Battery Temperature 1 (°F)
    TXD 07D2225018
    RXF C56200000000
    RXD 3810
    MTH 000703E8FFC6
    Hybrid Battery Temperature 2 (°F)
    TXD 07D2225018
    RXF C56200000000
    RXD 4808
    MTH 00FF00400000
    Hybrid Battery Temperature 3 (°F)
    TXD 07D2225018
    RXF C32100000000
    RXD 2010
    MTH 000703E8FFC6
    Hybrid Battery 1 Fan (%)
    TXD 07D2225002
    RXF C46280000000
    RXD 3808
    MTH 000500010000
    Generator Inverter Temperature (°F)
    TXD 07DF2210C1
    RXF C462051036C1
    RXD 3008
    MTH 00090005FFD8
    Perhaps there is a small error with one of the numbers, I know the scangauge site is not always 100% accurate. For reference, the car is a 2016 model with the Li-ion battery. Thanks in advance.
  2. ChapmanF
    15,697
    I notice that three of those have the same TXD; the values are packed together into the response for a single PID.
    Before a certain ScanGauge version, you couldn't have more than one such value selected for display at the same time, or they'd be blank. I don't remember what firmware version fixed that.
