Someone to install rear view mirror?
Discussion in 'Gen 2 Prius Main Forum' started by smtrader, Nov 13, 2005.
  1. smtrader
    smtrader Member
    105
    Cerritos, CA
    I want to replace my rear view mirror with one that has a compass. I have the mirror but need help installing it.
    Can anyone recommend someone in the Los Angeles area that can do this...and not charge an arm and a leg?? :D
    Thanks...Brian
  2. Tideland Prius
    16,445
    vfaq.net
    That should help. I assume it's the one from Johnson & Johnson. (i.e. Gentex)
  3. mysu
    mysu New Member
    I'm also interestred in installing a rear view auto-dimming compass mirror. Have you or anyone completed this project? Is there an electical connection near the mirror? Best brand for this application? :unsure:
  4. aaf709
    3,862
    2022 Prius Prime
    I've seen that the big worry (and this was about installing a Homelink mirror) is that you can't run the wiring up through the normal way because of the airbags. You may have to run the wires around the glass.
    If I didn't have the Homelink mirror, I'd do something like that, but it would be the rear camera mirror.
