Something is draining the battery
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mike82, Oct 30, 2017.
  1. Mike82
    Mike82 New Member
    Downey Ca
    Hello, I’ve done some research on this forum and sought advice other places and although my issue has been addressed in the past through other members, I can’t seem to find a solid answer. My battery seems to be draining (yes the battery is fine. I’ve had it checked as well and have even experienced the same issue when it’s fully charged. When I try turning my car on, sometimes the red triangle warning signal turns on and seems to be low on juice. This happens about every 2 Days. Sometimes EVERYDAY. Please help!!
    Ps i apologize in advance for my lack of car knowledge if I’m not working my question correctly.
  2. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    If the 12 volt battery is original it likely needs to be replaced. The loading on a Prius 12 volt battery is different than other cars. Many times if it has been discharged too low even once, it never recovers and needs replacement.
    The 12 volt battery just boots up the computers. In a traditional car, the battery is needed to start the engine too.
  3. Mike82
    Mike82 New Member
    Downey Ca
    i appreciate your prompt response. I’ve received the same opinion before , however there are a few things that lead me to believe it might not be that. There’s a beeping sound the car makes sometimes, as if the key is still in the ignition when it is not. Whenever the car makes this noise is when the battery is drained next time I turn it on. Also, there was about a 2 month period where the battery never drained after about 6 months of doing it. Then all of a sudden it happened again. If it was the batterndo u believe it would’ve still charged up completely when I took it to the auto store?
  4. Mendel Leisk
    38,648
    Is it the original battery though? All bets are off if it is: replaced it first, ensure the new battery is fully charged before installing.
    That aside:
    How are you having it checked? An electronic load test? Or?
    How are you charging it, or having it charged? A full charging session with a smart charger? Or?
    Any added-on accessories that might be using electricity when the car's off?
    You could check for phantom loads: disconnect the neg lead, and splice in (in series) a multimeter set to ampere scale. Commence with ampere, and then switch to millampere, for safety. Run leads out through the hatch and gently close it on them. Let the car sit for 20 minutes, then see what kind of milliamps you have. Around 20 with just occasional spikes is what I've read, which seems typical.
    #4 Mendel Leisk, Oct 30, 2017
  5. Mike82
    Mike82 New Member
    Downey Ca
    I do not know if it’s the original battery. I had it charged at an O’Reillys
  6. Mendel Leisk
    38,648
    Start with an electronic load test I think. Most battery retailers will provide this service for free. Or for DIY, google Solar BA5
  7. Mike82
    Mike82 New Member
    Downey Ca
    (Again please excuse my lack of knowledge) but is it possible that if brake work needs to be done, the triangular warning sign will be turning on for that and draining the battery in some way??
  8. bisco
    49,379
    since you have dash warning lights, you have trouble codes set. you need to go to a dealer, or someone with a prius aware scanner to get the trouble codes.
    Prodigyplace likes this.
  9. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    If the car is off there should be no extra drain even if there is a problem elsewhere in the car. The lights you see may be from the computers being confused because your battery is low.
    Batteries can short internally from various causes and that won't show on a test. I just had one do that to me. They go dead in a day or less and a test won't show the short. It can be tested for but not by any of the standard battery testing methods.
    If this is your 2009 Prius the most likely problem is the battery is too old/has gone bad. They only last 3-5 years for most people.
  10. fuzzy1
    10,159
    If it is the original 12V battery, then it is 8 to 9 years old. That is seriously old even in my battery friendly climate zone. Your LA area summer heat is less friendly.
    Weird stuff happening? MPGs dropping? Test The Battery
  11. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    NO. But when batteries get old and weak, the battery itself will "self discharge" when just sitting there.
    AND the standard battery tests don't always give reliable results.
    If you MUST get a test failure to convince you, take it in to the battery shop to have it tested near to the time it has failed and do the test WITHOUT first changing it up. They can also test your charging voltage at the same time.
    But I agree with the others that the battery itself......or a bad connection on the main cables......is very likely the source of your problem.
  12. Wired89
    Wired89 New Member
    Long Beach
    I'm having this same issue. Sometimes my car turns on other times it doesn't. It 100% is not the 12v battery but that doesn't mean it's not a bad connection somewhere. If you find out what's going on with yours please tell me and if I find out I'll tell you. I think we are having the same issue
  13. Sam Spade
    2,036
    1,023
    2017 Prius c
    What exactly leads you to that conclusion ?
    MANY other folks have said that in the past........only for it to turn out that it IS the 12 V battery after all.
    Even brand new ones sometimes fail.
  14. Grit
    Grit Senior Member
    6,141
    4,053
    Wilkes Land
    I'd do this also if you haven't. Also inspect both battery terminals and reseat.
  15. bisco
    49,379
    could be your brake switch.
