Something turns on when I go near the car
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by brakeshoe87, Jun 10, 2013.
  1. brakeshoe87
    brakeshoe87 Junior Member
    I have a 2012 Prius 2. Every once in a while when I get near the car or open the door there is a mechanical sound from the front of the car. It lasts for about 5 seconds but not long enough to open the hood and see what is running. The dealer suggested it was the fan, but there is no reason the fan would run after the car was sitting in the garage all night. Anyone have any suggestions on what this could be and how to correct it?
    Thanks
    Dave
  2. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    IIRC- it's the brake system vacuum pump making sure there's boost for the brakes.
    49,490
    where did you take it, a bmw dealer?:p welcome to priuschat! did you get a manual with the car?
  4. brakeshoe87
    Took it to my Toyota dealer and they had no clue. I looked through the manual but did not see anything that sounded like my problem. I am not sure why walking past the car should trigger a brake pump. It seems like that would be more appropriate when I am about to drive the car and not when I am taking out the trash. I also question why if this is the case, does it only do it on very rare occasions.
  5. hubmacfan
    hubmacfan Junior Member
    57
    Hattiesburg, Mississippi
    You must have the smart key in your pocket when you're walking by. The system is assuming you're about to get in the car and drive it.
  6. Batavier
    Batavier Member
    442
    The Netherlands
    Mine does that as well. It's a small whirring sound. Try sneaking up on your Prius without the smart key... see if that helps. :) They're devious little cars, these Priuses. :)
  7. PLSPUSH
    PLSPUSH Active Member
    359
    132
    Tulsa, Okla.
    try turning it off, and sitting it for half an hour, you would think it was haunted because of all the noise it makes!
