Something's missing...
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by rkho, Mar 11, 2013.
  1. rkho
    rkho New Member
    Oakland, California
    I think this is the fuel restrictor or anti-siphon door, but it seems to have disappeared. Also, my check engine light is on.
    Would this happen to be related?
  2. PriusInParadise
    180
    91
    Hawaii
    There is nothing missing. Toyota relocated the flapper valve to the tank inlet in 1997 or 1998. Other makes, like GM still puts the flapper valve at the filler.
    As far as your check engine light, unless you know for a fact that the gas cap was loose, you really need to use a scan tool to see which module set what trouble code(s).
    For a loose gas cap, the check engine light may need a few days to a week of normal driving before turning off. The on-board diagnostic has to run and pass three consecutive times to turn off the light. For most evap codes, that means at least 3 warm-up cycles. Cold start, drive until normal operating temp, park at least 5 hours, repeat two more times.
    tanasit likes this.
  3. B2FiNiTY
    B2FiNiTY Active Member
    979
    226
    Like the top poster said, that is completely normal.
  4. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Although the light goes out the code is still set so after it is read it should be cleared. In NJ that would cause the car to fail inspection.
  5. PriusInParadise
    180
    91
    Hawaii
    In general, most ECM DTC's will clear from memory after passing 40 diagnostic cycles. Misfire DTC's must pass 80 diagnostic cycles to clear. DTC's in other modules such as ABS and SRS may remain in history until cleared with a scantool.
