Something's Wrong
Discussion in 'Gen 2 Prius Fuel Economy' started by Don Felts, Aug 20, 2024 at 5:26 PM.
  1. Don Felts
    Don Felts Junior Member
    Mississippi
    I've never posted much once or twice. When I had a problem. Thanks guys for the support. I have a 2008 Prius base. Has over 315000 miles on it. I've driven it for years. I commute 180 miles 4 days a week. My average has been 42-47. Depending on tires. My tires are pretty worn. Goodyear Fuel Max Radials. Bought them in July 2022. They have over 70000 miles on them. Probably 80000. You know as tires wear mph goes up . I used to use Bridgestone Ecopia EP422. The Bridgestones. Didn't last very long. They could blow out anytime. I pumped all 4 tires to 42#
    Yesterday I filled up at Murphy's. I noticed the fuel smelled very rich and strong. More than usual. I drove 90 miles. I noticed my gas didn't change much. I stopped at Kroger to fill up. Kroger fuel cost less $2.67 a gallon. The tank held $2.00! 3 quarts! I drove a Honda Insight for many years on the same commute and the best MPGs I ever got was 75 MPSs. I was drafting a semi with a 15 mph tail wind. I can't believe it went 90 miles on 3 quarts. That's a little over 100 mph. It had to be the fuel. Nothing else explains it. I'm certain I put low test in it. I've never put anything else in it. I guess there is a chance the the trucker got the fuels mixed up. I've always believed the Prius won't do better on hi test. I've never even tried it. If I'd known I could get over 100 MPGs using premium I would have. What do you guys think? Has there ever been similar experiences?
    Thanks for looking.
    Donald Felts
    #1 Don Felts, Aug 20, 2024 at 5:26 PM
