SOMS Technologies microGreen Oil Filter
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by crayola, Jun 16, 2009.
  1. crayola
    crayola Junior Member
    35
    San Jose, CA
    I use mobile 1 and change oil/filter every 10k miles and do mostly highway driving up and down I5 and 101. I thought about giving this filter a try. What do you guys think?
    The company claims the microGreen filtration system allows your vehicle to operate up to 30,000 miles without changing the engine oil.
    http://www.microgreenfilter.com
    I wonder if a car will ever need it's oil changed onces or twice in a life time.
  2. Duffer
    Duffer Member
    271
    Wow! 45 bucks for an oil filter, it must be good. I would buy an Amsoil filter and 4qts of 0w30 Signature Series oil for about the same price . Extend oil drain intervals according to vehicle use.
  3. dogfriend
    7,512
    1,189
    Carmichael, CA
    Based on their description, they have designed a bypass oil filter inside the regular full flow filter housing. If it works as advertised (I'm a little skeptical without independent testing) then you probably could extend oil change intervals to 30k, especially since you are running 10k now.
    If you decide to do this, I would recommend having UOA (used oil analysis) done at 10k intervals to make sure that the oil is still working well for you. This would cost $20 - 25 each time plus makeup oil (~ 8 oz or so for a sample each time).
    This is how large industrial equipment and large diesel engines are often run; because the volume of oil is so large, it is worthwhile to regularly test it and only replace it when needed.
