Son has my Prius 300 miles away and having a problem
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JStrenk, Aug 12, 2016.
  1. JStrenk
    JStrenk Active Member
    203
    101
    Ravenna
    My son took my Prius to drive to his National Guard base and the Prius started to make a dragging noise.
    What is this and what can he do?
    There are no Warning lights or anything else.
  2. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
    muffler hanger.
    replace it or bend it back in shape.
    BION
    StarCaller
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    Remove it or bend it out of the way. Then jack it up and have that part remove and replaced.
  4. Vman455
    Vman455 Senior Member
    534
    551
    The Middle
    That's the hanger for the resonator, looks like it has bent but still attached and the welds look intact. A quick check of Rock Auto shows the resonator only available with the catalytic converter as a single part, at several hundred dollars, but there's no reason to replace here. My recommendation is bend it up and back into position as well as you can; the rod part with the rubber hanger should point forward. Then replace the rubber hanger/insulator if that's torn (it probably is, they're $4-5). Good luck!
    hotelprisoner likes this.
  5. StarCaller
    1,246
    697
    the question you might rather want to ask your son is what happened before it started to make a dragging noise..../ ;)
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    You are not supposed to drive over the wheel stops? Who knew?
    bisco and Raytheeagle like this.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    And after asking the above, you might want to do further under body inspection:(.
  8. JStrenk
    203
    101
    Ravenna
    I think I have to ask son #2 about that :(
    He's like that. He had the car for a couple of days while fix his car:
  9. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    Looks like whatever he found, it left a mark:eek:.
    Your boys appear to keep you busy:). Hopefully the Prius is only the hanger and nothing further.
    Good luck!
  10. Mendel Leisk
    38,726
    A good item to add to the subfloor tray is some wire, stiff baling wire or similar.
  11. bisco
    49,489
    understood, i have 3 children. fortunately, they now have their own cars, or use uber.:cool:
  12. NutzAboutBolts
    1,476
    1,552
    Bay Area
    the question is... will your son be paying for it? :ROFLMAO::ROFLMAO::ROFLMAO:
    on a serious note, do inspect the button and see if anything else is damaged. (y)
  13. JStrenk
    203
    101
    Ravenna
    I told him to bend it up but he didn't want to get dirty so I told him he could pay for the tow and repairs if he hits something on the way home.
    Raytheeagle and StarCaller like this.
  14. JStrenk
    203
    101
    Ravenna
    Well I know you guys are wondering how he made out. Well he made it home but pulling into the driveway he hit a rise and bent it near vertical.
    I could not bend it by hand and so I put a pipe on it. Got it about 80% of the way when I heard a crack. And a couple more wiggles and it popped right off. But I was able to fab up a substitute for it and after a little grinding and drilling, I got er dun! :)
    bisco and StarCaller like this.
  15. JStrenk
    203
    101
    Ravenna
  16. Vman455
    534
    551
    The Middle
  17. Mendel Leisk
    38,726
    Toyota's bolt longevity isn't too impressive:
    Raytheeagle likes this.
  18. JStrenk
    203
    101
    Ravenna
    Funny how some stuff rust so bad and other things don't rust at all.
    Is that a seat bolt?
  19. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    Was there any other damage to the undercarriage or explanation provided to your additional work? Or did the road "come out of nowhere and bite them":whistle:?
  20. JStrenk
    203
    101
    Ravenna
    The only thing I see is the bottom of the bumper cover was hit again.
    No obvious scrapes any place else. That mount is tucked up there a way. Can't figure out how it could snag without any other damage
