Sound from air vents when AC first turned on
Discussion in 'Gen 3 Prius Main Forum' started by pctra, Mar 20, 2010.
  1. pctra
    pctra Junior Member
    CA
    Sometimes when I first turn on the air/AC, I'll hear a soft whirring or grinding sound that seems to be coming from the air vents. If I turn off the air and then turn it back on, the sound goes away. It doesn't happen often; I only remember noticing it a handful of times.
    Has anyone heard this sound before, or do you know what causes it? I'm wondering if it's normal or something that needs to be fixed.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The Prius uses electric motors to position the baffles in the A/C system. I suspect this is what you hear.
    Tom
  3. pctra
    pctra Junior Member
    CA
    Thanks for the info!
  4. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    pctra,
    At least in the Gen II, the soft whirring and door closing sounds on
    start up of the air conditioning -- meaning either heating or cooling
    -- comes from the servo motors setting baffles in the ductwork to
    direct air as as desired. I hear it when I change output location, say
    from defrost to feet & face. I would say that unless the sounds are
    very loud, or sound particularly strained, there is litttle to worry
    about.
    I suspect that the Gen III is pretty much the same.
    One caveat: If you live in a rural/suburban area, be mindful that
    mice and chipmunks have a particular fondness for setting up
    houskeeping in a Prius' ductwork. So a loud or strained sound could
    mean a stuck baffle due nesting, etc.
    But just in case, let's wait and see if a Gen III-er chimes in.
    Hope this helps.
  5. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    It could also be the compressor when it first turns on.
  6. pctra
    pctra Junior Member
    CA
    Thanks for the detailed info. It's good to know that the sound is normal. :)
