Sound proofing
Discussion in 'Gen 4 Prius Accessories and Modifications' started by husami, Jun 24, 2021.
  1. husami
    husami Junior Member
    50
    Cincinnati, Ohio
    Is there a way to make the cabin more sound proof from the outside noise. I like to reduce it about %10 to 20%
    52,373
    yes, but it takes some work. there are threads here and maybe youtube detailing panel, headliner and carpeting removal, and adding sound deadening mats to great effect.
  3. BellevilleMXZ
    BellevilleMXZ Member
    72
    61
    Ontario,Canada
    2024 Prius
    Limited AWD-e
    Interesting....are older ones noisier? I find ours fairly quiet?
  4. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    I sound deaden the doors and it produced some but pretty minimal noise reduction. Nothing close to sound proof at all. For freeway speeds, it will be near impossible to sound proof. I did not do the roof, floor, or trunk, which will help more but as mentioned, a lot of effort.
    kenoarto likes this.
  5. brenthon
    brenthon Junior Member
    GA
    A bit pricey but Dynamat is a good sound deadener.
  6. audiodave
    audiodave Active Member
    800
    272
    US
    Did you cover over the open holes of the inner doors?
  7. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    I used Stinger Roadkill for the sound deaden material. The front doors, with my 2019 version, has a pretty decent plastic that is held on by clips, which I temporarily took out so I can sound deaden the external metal. The inner portion that holds the speaker, I sound deaden as well. There's really no major holes besides the beefy plastic. The rear doors on the other hand are the thin cheap film plastic. I left the cheap plastic. My main goal of sound deadening is to absorb rattling from the bass from my new speakers, not to sound proof, which the product I picked did a good job in that matter.
  8. Valiant V
    Valiant V Member
    239
    161
    Winnsboro, TX
    What kind of "outside noise" are you trying to reduce?
    Our 2017 (three) is pretty quiet EXCEPT for the tires on rough roads. That got a bit worse when I inflated the tires properly (36/35) from where they were when we got it. I suppose lowering the tire pressure would alleviate that somewhat - not sure how badly the mileage would suffer.
    I had read some reviews of the car that said the engine was "loud" - we don't find this to be true at all.
    We don't seem to have a lot of wind noise either.
    I say all this having come from a 2000 Ranger pickup running really rough (loud) Texas Chip-seal roads that make any vehicle with high-pressure tires scream.
    Mambo Dave likes this.
  9. audiodave
    800
    272
    US
    Well the plastic does very little for stopping noise from the outside. Something of density like the deadener works. It wouldn't hurt the speaker performance to use the deadener over the holes as well. As far as what your wanting out of it.
