Sound through aux
Discussion in 'Gen 2 Prius Audio and Electronics' started by UK-Prius, Mar 17, 2013.
  1. UK-Prius
    UK-Prius Junior Member
    UK SOUTH WEST
    Hi
    Using aux on gen 2 2008 and when is plugged in to the power supply as well I get the popping sounds of the phone maintaining its phone signal , when I unplug it the signal sound stops.. I drive for 4.5 hours and use the phone for pod casts and sat nav.. Do it does need to be on charge
    Martyn
  2. shikataganai
    shikataganai Junior Member
    30
    Seattle, WA
    Solution: unplug it from the power unless you need to charge it desperately.
    (I also found that audio quality was very limited when both charging and using the headphone jack -> 3.5 mm aux in on my '06 via the built-in aux in on the JBL system.)
  3. seckwielen
    seckwielen Member
    112
    26
    Pretty common phone issue. Wife's Toyota Sienna and my Prius both have a slightly detectable whine through the aux when charging the iPhone.
  4. e6matt
    e6matt New Member
    Plug your aux cable into a "ground loop isolator" like this:
