Sound when accelerating the first time after a start
Discussion in 'Gen 4 Prius Technical Discussion' started by Ranko Kohime, Mar 24, 2019.
  1. Ranko Kohime
    Ranko Kohime Member
    71
    32
    Ohio
    Two Eco
    As the title implies, there is a sound when accelerating, around 12-13 miles an hour, ONLY the first time you exceed that speed after starting, and ONLY when it's warm enough that the engine doesn't automatically kick on straight away. (It may happen when it's cold enough that engine does start, but I can't hear it over the engine)
    It's a "sproing", that sounds vaguely similar to a door stop spring. It's not the brake booster, that sound I've come to be very familiar with.
    I'm not worried about the sound, but I'm extremely curious what it is, and what it's doing.
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    961
    542
    Cow-lee-fornia
    2023 Prius
    We'd need a recording of the sound in order to identify it. The Prius makes a lot of noises, some strange to the first time owner.
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Mine has done it since new. I think there's some thread somewhere that addresses it. Try searching...
    52,382
    sounds like a sticky suspension bit or brake caliper. i get a good creeping noise every time i back out of my driveway and the car is between the angled driveway and the flat street. happens the first time of the day only.
  5. CooCooCaChoo
    961
    542
    Cow-lee-fornia
    2023 Prius
    Mine makes a thud when pulling out of my parking spot on first drive in the morning also. I figured it was either suspension related or brake related due to rust overnight. Nothing to be worried about.
  6. Ranko Kohime
    Ranko Kohime Member
    71
    32
    Ohio
    Two Eco
    I made a recording of the sound, hopefully it's clear enough.
    WARNING: I boosted the audio level up, so turn your volume down a bit before listening.
    Sound Clip
  7. Ranko Kohime
    Ranko Kohime Member
    71
    32
    Ohio
    Two Eco
    Definitely not rusty rotors, that is a much different sound (though I will say I'm shocked how quickly the rotors develop surface rust on this thing. Overnight in the rain compared to several days in the rain for my other cars)
    It sounds too purposeful of a sound, and too consistent, to be a flaw, it sounds like it's doing something intentionally.
  8. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    The rotors will look rusty - because you don't use the brakes a lot of the time, so aren't wearing the rust off every time you press the brakes. Don't worry about them, the brakes will last 4, maybe 6 times longer than in a "normal" car.
  9. bisco
    52,382
    is it the auto door locks?
    alanclarkeau likes this.
  10. CooCooCaChoo
    961
    542
    Cow-lee-fornia
    2023 Prius
    Yeah, might be auto door locks. Manually lock doors before taking off to see if it eliminates it as a suspect.
  11. Ranko Kohime
    Ranko Kohime Member
    71
    32
    Ohio
    Two Eco
    No, those lock when I shift into Drive. This sound occurs around 12-13 MPH, and sounds like it's coming from in front of the left front wheel.
  12. bisco
    52,382
    not the pedestrian warning system?
  13. Ranko Kohime
    Ranko Kohime Member
    71
    32
    Ohio
    Two Eco
    As in a pedestrian warning, or the system doing some kind of startup procedure? I have never seen a pedestrian warning, (peds around here have played Carmageddon and generally know better than to walk out in front of cars :D), and the sound is a bit more mechanical than I would expect from something that should be entirely sensor-based. Unless Toyota has invented some Rube Goldberg type of device. :p
  14. bisco
    52,382
    it is an electronic kind of whirring sound. if you roll the drivers window down, and drive slowly in ev only inside a garage or similar, you can hear it. the speaker is in front of the drivers side wheel.
    you can also find you tube demonstrations. i believe gen 4 allows you to set volume levels.
    VPNS: vehicle proximity notification system, it should be in your manual.
    there is a thread here on disabling: in the 'gen 4 prius accessories and modifications forum'
    search 'Vehicle Proximity Notification System' by member randomwalk101
    #14 bisco, Mar 29, 2019
  15. Ranko Kohime
    Ranko Kohime Member
    71
    32
    Ohio
    Two Eco
    If my car had that, and unless I missed something I don't believe my Two Eco even has that option, it would long since have been disabled due to the annoyance it would cause me.
    Yes, my hearing is that sensitive, in spite of all the loud music my parents used to complain about when I was younger. :whistle:
    I can say with certainty it's not that, the sound is very different, and also, momentary, (only occurring on acceleration ONCE after the car is started) not sustained like the VPNS.
    The mystery deepens.
  16. bisco
    52,382
    sounds like two separate sounds in your recording, one right after the other
  17. Ranko Kohime
    Ranko Kohime Member
    71
    32
    Ohio
    Two Eco
    Didn't even notice the other sound when I edited. First sound is phone-handling noise, second sound (ends at the 0:02 mark) is what I'm hearing.
  18. GRich
    GRich Junior Member
    28
    16
    Are you sure it's not the brake test. It makes a single soft squick noise around that speed
    "When the vehicle speed reaches approximately 20 km/h (12 mph), the initial check of the brake actuator assembly is performed and pump motor operation sounds are generated"
  19. wfolta
    wfolta Active Member
    366
    146
    Washington DC
    2018 Prius
    I experience something like this and it sounds like a belt slipping once. Sort of like a cross between a chirp and a zipping sound, as if a belt slipped for a moment and then caught. Definitely not a screeching sound like old-school belts truly slipping. Maybe something like a long zip tie being tightened rapidly.
    #19 wfolta, Apr 13, 2019
  20. Elektroingenieur
    2,515
    3,287
    Three Touring
    It’s the brake test, as @GRich kindly mentions above; mine does it too, and it sounds just as you describe. The car has no belts, since the air conditioning compressor, water pumps, etc., have to be able to operate when the gasoline engine is stopped.
    rosencrantz likes this.
