Source for good exterior hatch release button cover?
Discussion in 'Gen 2 Prius Technical Discussion' started by Galane, Jun 1, 2020.
  1. Galane
    Galane Junior Member
    77
    24
    Idaho
    Another day, another little thing. The rubber-ish cover on the hatch release button on the 09 has become a gooey mess. I had a look on eBay and found some replacements but am wondering about how good they are.
    What is up with these terrible soft compounds for parts like this? That deterioration should have been well known and whomever specified such a material for that part should've known better.
    Or perhaps that property is why it was chosen. A person on another forum admitted working for Ford on the design of dash parts and how they carefully chose the TPU overmold material to not be too durable so it'd eventually go bad, peel off and look terrible.
  2. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    I finally got sick and tired of playing five minute finger pool with mine, so I replaced the melted cover with a new one, yesterday.
    A $9 kit with the cover and all tools needed to remove it and scrape the melted mess off can be had on Amazon.
    I watched a two minute video on YouTube to see what to remove and it took me about twenty minutes, most of the time taking to remove the goo.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,094
    1,998
    NJ-USA
    Hmmm. Don't know if some buttons were made with different rubber material, or if exposure to sunlight or certain chemicals is causing this. The buttons on my 06 are still fine.
    Nice to know that reasonable replacements are available.
  4. Another
    1,819
    517
    Naples, Florida
    The button was fine and in excellent working order, once I removed the melted rubber like cover. The rubber had degraded so much that it had to be scraped out of all the nooks and crannies of the button. I could have replaced the whole button but after a thorough cleaning of the melted rubber I found it worked fine. The cause of this is probably the specific formulation of the rubber like material that allows the plasticizer to migrate to the surface and start dissolving the whole block of material.
    Toyota had a similar problem with their 2007 era dashboards that they eventually replaced for free.
  5. ChapmanF
    18,567
    Did you replace the rubber, or are you now just pressing the nekkid button?
  6. Another
    1,819
    517
    Naples, Florida
    Yes, replaced. The $9 kit comes with the rubber piece, scraper, new screws and even an angled Phillips screw driver.
    The scraper was just the right size to get into all of the crevices that the goo migrated into.
    The OEM switch looks like it’s pretty high quality and it now works fine.
